Configuration advice please - $3000.00 Max.Post Date: 2011-04-20 |
| Author | |
LWRC_REPR
Joined: 28 Jan 2011 Online Status: Offline Posts: 17 |
Topic: Configuration advice please - $3000.00 Max.Posted: 20 Apr 2011 at 9:30pm |
Hi,
I am looking to get a new desktop that will be used for gaming, watching Blu Ray & DVD movies, listening to music, word processing, internet surfing, and maybe some drawing & 3D modeling
I do have an XBOX360 so I may still use that for gaming as well.
But, I am due for a new computer anways as my current Dell is over 10 years old with 512mb RDRAM, a Geforce Ti200 GPU, and a 80GB HD,
Ideally, in reference to gaming specifically, I want to experience the legendary "Crysis" with high/max settings with a smooth frame rate
I came up with a configuration and would like some feedback. I think I could max out at $3000.00 if need be. But, my preference is to keep it under 3K given that my monitor, mouse, keyboard, and surround speaker system will add another several hundred to the final price. Here are my current choices for these devices and I would appreciate feedback equally:
**MONITOR: either the Acer GD235HZ LCD as it is 3D ready OR the Samsung P2370 HD which has a slower ms time and is not 3D ready but is less costly.
**KEYBOARD: either the RAZER Black Widow Ultimate mechanical keyboard OR the Logitech G510 Gaming Keyboard.
**MOUSE: Steelseries Ikari
**SPEAKERS: Logitech Z-506 5.1 surround system.
Ticket Number: 526497
Total Price with Instant Savings: $2,784.00 Direct Load URL: http://www.digitalstormonline.com/comploadsaved.asp?id=526497
Chassis Model: Special Deal Hot Seller - Cooler Master CM 690 II Advanced Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 2600K 3.40GHz (Unlocked CPU for Extreme Overclocking) (Quad Core) Motherboard: ASUS P8P67 Deluxe (Intel P67 Chipset) (New & Improved B3 Revision Without SATA 3G Issue) System Memory: 8GB DDR3 1600MHz Corsair Dominator DHX (High-Performance) Power Supply: 1000W Corsair (Dual/Triple/Quad SLI Compatible) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (120GB Solid State (By: Intel) (Model: 320 Series SSDSA2CW120G3K5) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar (7200 RPM) (64MB Cache) (Model: Black Edition WD1002FAEX) Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: Blu-Ray & DVD Writer/Reader (Burn + Play Blu-Ray & DVDs) (12x BD-R) (Lite-On iHBS112) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 1x NVIDIA GeForce GTX 580 1.5GB (Includes PhysX) (Overclocked Edition) Add-on Card: - No Thanks Sound Card: Creative Labs X-Fi Titanium Fatal1ty Champion (Includes Front I/O) (PCI-Express Slot Based) Extreme Cooling: AIR: Stage 1: High Performance Cooler (Compatible With i5/i7/AMD Processors) H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: - No Thanks Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks Boost Processor: FREE: Overclock the processor between 3.6GHz to 3.9GHz Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Recovery Tools: Advanced Recovery Kit (40GB Hard Drive Partition of Image With OS & Drivers) Virus Protection: - No Thanks Office: - No Thanks Benchmarking: - No Thanks Install/Test Game: Crysis: Maximum Edition (Includes: Crysis, Crysis Warhead, Crysis Wars) Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Xtra Large) Priority Build: - No Thanks, Ship Within 5-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Customer Care with 3 Year Limited Warranty THANK YOU!
ablahblah
Joined: 12 Jun 2009 Online Status: Offline Posts: 2312 |
Posted: 21 Apr 2011 at 1:18am |
Swap in a better case like the HAF X, give it some well deserved processor cooling (Noctua U-12P or go Sub-Zero LC), throw in some case lighting, and drop Crysis Maximum Edition to just grab Crysis 2 at Gamestop or something. Then you're all set.
R4D4RPR00F
Core i7 920 @ 3.9Ghz Asus Sabertooth X58 EVGA GTX 570 Mushkin 6GB 1414Mhz |
Posted: 21 Apr 2011 at 2:34am |
You can't play metro and crysis at highest settings with 4xaa with a single 580/570, the same for 3d, you need sli:
Here you go Ticket# 526698 --- $2792 (To see this build click here) Copy of Specifications: Chassis Model: Special Deal Hot Seller - Cooler Master 942 HAF X Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 2600K 3.40GHz (Unlocked CPU for Extreme Overclocking) (Quad Core) Motherboard: ASUS P8P67 Deluxe (Intel P67 Chipset) (New & Improved B3 Revision Without SATA 3G Issue) System Memory: 8GB DDR3 1600MHz Corsair Dominator DHX (High-Performance) Power Supply: 1000W Corsair (Dual/Triple/Quad SLI Compatible) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (120GB Solid State (By: Intel) (Model: 320 Series SSDSA2CW120G3K5) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar (7200 RPM) (64MB Cache) (Model: Black Edition WD1002FAEX) Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: Blu-Ray & DVD Writer/Reader (Burn + Play Blu-Ray & DVDs) (12x BD-R) (Lite-On iHBS112) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 1x NVIDIA GeForce GTX 570 1.2GB (Includes PhysX Technology) Add-on Card: - No Thanks Sound Card: Creative Labs X-Fi Titanium Fatal1ty Champion (Includes Front I/O) (PCI-Express Slot Based) Extreme Cooling: AIR: Stage 1: Noctua NH-U12P SE Dual 120mm Fans High Performance Cooler H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: - No Thanks Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks Boost Processor: Stage 1: Overclock the processor between 4.0GHz to 4.5GHz (Cooling Upgrade Recommended) Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Recovery Tools: Advanced Recovery Kit (40GB Hard Drive Partition of Image With OS & Drivers) Virus Protection: - No Thanks Office: - No Thanks Benchmarking: - No Thanks Install/Test Game: Crysis: Maximum Edition (Includes: Crysis, Crysis Warhead, Crysis Wars) Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Xtra Large) Priority Build: - No Thanks, Ship Within 5-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Customer Care with 3 Year Limited Warranty Ask DS specifically for this fan to be added to the top, so you endup with 4 x 200mm fans: haf 200mm non led fan Add the second gpu yourself down the road, it would go over the budget right now. you sure 8GB is enough for your 3D modeling? |
ablahblah
Posted: 21 Apr 2011 at 3:04am |
wait, did he want to go 3D? i thought he just said he was debating between a 3D "Ready" monitor and a regular monitor.
R4D4RPR00F
Posted: 21 Apr 2011 at 3:06am |
he said it at the beginning ablah, unless I missing something
ablahblah
Posted: 21 Apr 2011 at 3:07am |
3D modeling as in Blender and stuff?
R4D4RPR00F
Posted: 21 Apr 2011 at 3:15am |
LOL I'm assuming, I don't know.
which is why I asked, lets see what he says
LWRC_REPR
Posted: 21 Apr 2011 at 7:13am |
I originally went with the cooler master case because I wanted something a little more streamlined than the HAF X. However, the HAF X, in terms of room and ventilation seems to always comes out on top. Thank you for the new ticket. I will build off of there. I want to be able to watch movies and possibly get into 3D modeling down the road. Watching BLU Ray movies takes precedence now though. My configuration should even allow me to watch BLU Ray movies in 3D with the addition of the right glasses. That is why I nominated the Acer monitor. I realize I will need more RAM if I get into 3D modeling though. Probably double what I have chosen so far, 16gb vs. 8gb. But, I figured I could always add that down the road when the time comes. I believe the MOBO will support that amount.
I have been debating between the 570 and the 580 as far as GPU's go. I chose the 580 OC version because it does edge out the 570 in most reviews I read. And with my MOBO and RAM choices/speeds I figure it will perform slightly better than with some of the test rigs in the reviews I have seen so far. Then I could go SLI with another 580 down the road as they come down in price and my needs require the additional power.
What kind of frame rates are desirable when playing Crysis, Crysis 2, etc? My estimates are that I might hit 36 to 40 with my current configuration when playing Crysis with 4xAA and 1920x1080. Thinking of the future, would a SLI 580 setup be able to handle Metro2033?
Off to work. TTYL.
Posted: 22 Apr 2011 at 1:55am |
For watching movies in BD and 3D just about any of todays gpu should do.
the difference between 570 and 580 is not enough to spend money on a 580, on metro there is I think like 4 fps difference, and in crysis there is a 6 fps difference, you can always oc the 570 easily and get those fps back. never go with a oced version of the gpu. in metro you gonna be in the 20s with both 570/580 and in cysis in the 30s with both again. If you want to go to 16GB of ram, then make sure you go with win7 pro, home version supports 16GB total, that includes vram, so that won't work for you. Edited by DST4ME - 22 Apr 2011 at 2:03am |
dANGLICO
Joined: 10 Mar 2011 Online Status: Offline Posts: 29 |
Posted: 22 Apr 2011 at 2:06am |
"never go with a oced version of the gpu. " DST4ME
Why should you never opt for an OC'd GPU? Does DS do a more effective OC?
"In absence of orders go and find something to kill." Field Marshal Erwin Rommel.
Capt J |
Posted: 22 Apr 2011 at 2:52am |
No from my experience teh oced version of cards are not as reliable.
and you can oc it much higher yourself, gpu oc unlike cpu oc is very easy to do. the DS oc is very mild. |
