configuration comparison help
Post Date: 2007-11-09
rallymaster View Drop Down
Guest
Guest
  Quote rallymaster Quote  Post ReplyReply bullet Topic: configuration comparison help
    Posted: 09 Nov 2007 at 10:15pm
Hello Folks,
My wife has granted me three wishes,  and one of them is a new system since my old computer finally gave up and had a physical hd failure.  I've been patient for the last 3 months and now I have the green light.
Based on my given budget,  I've put together 2 systems,  one AMD based and one Intel based.  Not being as well versed as many here,  I would like to hear your opinions on which system to pursue...
I mainly use my gaming system for racing simulations (GTR2, rFactor, RACE) as I'm a racer in real life,  and the newest sims are quite good and keep me in good practice.  I have selected a single 8800GT based on most discussion here,  and would like the option to add a second in SLI in the future.  Without further adieu,  these are the 2 configs I have.  Any tips or suggestions regarding my selections are much appreciated.
Total Price with Instant Savings: $1,519.00
Case: Digital Storm Twister PRO (Black Anodized Aluminum Finish)
Power Supply: 750W Silverstone (Dual SLI Compatible) (Silent Edition)
Processor: AMD Athlon X2 6000+ 3.0GHz (Dual Core) (2 MB Cache) w/HyperTransport
Motherboard: Asus M2N-E SLI (nForce 5 series SLI Chipset)
Memory: 2GB DDR2 Corsair at 800MHz Dominator (Dual Channel) (High-Performance)
Floppy / Media: - No Thanks
Hard Drive 1: 320GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Hard Drive 2: - No Thanks
Raid Option: - No Thanks
Modem: - No Thanks
Video Card: nVidia GeForce 8800GT 512MB (By: eVGA) (PCI-Express)
TV Tuner: - No Thanks
Sound Card: Motherboard Multi-Channel High Definition Audio (7.1 Channel)
Physics Card: - No Thanks
Cooling: Air Cooled Stage 1 (Certified Digital Storm Heat-sink)
Case Lighting: Blizzard Internal Lighting (Red Edition) (Cold Cathode Tubes)
Round Cables: - No Thanks
Protection: - No Thanks
LCD Display: - No Thanks
and:
Total Price with Instant Savings: $1,552.00
Case: Digital Storm Twister LITE (Black Aluminum Edition)
Processor: Intel Core 2 Duo E6750 2.66GHz (1333MHz Front Side Bus) (4MB Cache)
Motherboard: nVidia 650i Core 2 Quad (By: eVGA) (nForce 650i Ultra)
Modem: - No Thanks
skyR View Drop Down
Digital Storm Apprentice
  Quote skyR Quote  Post ReplyReply bullet Posted: 09 Nov 2007 at 10:47pm
Intel performs better than AMD and since they are both at $1500, go with the Intel.
If you are not going to overclock, you don't need Dominator ram so save some money and get XMS2 instead.
The 650i motherboard does not support SLI. You will need to select the 680i motherboard if you are interested in adding another card in the future for SLI.
A 620W PSU can handle a 8800GT SLI easily.
I would suggest upgrading to the Pro case as well for the Intel build if you are planning to go SLI in the future.
Tyler Lowe View Drop Down
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 09 Nov 2007 at 11:04pm
Before offering too many suggestions, may I ask, what is your typical replacement timeframe for a gaming system?
Also, what is your absolute budget ceiling?
Guest
Guest
  Quote rallymaster Quote  Post ReplyReply bullet Posted: 09 Nov 2007 at 11:29pm
thanx sky for your suggestions,  especially for catching my motherboard issue!  That would've really blown if I had continued not to realize that.
Tyler:
My last system served me well for 5 years,  but I had a shop do some significant upgrades (mobo, memory) 3 years ago,  and I also "upgraded"  the vid from a 5700 to a 6800 a year and a half ago.  As I don't play shooters or RPG's,  I don't really need the newest and baddest system for the newest and baddest games to remain interested every year.  And I'm pretty content with the current state of racing simulations.  Us simmers don't really stray too much in the community,  as there is still a huge following for GPL,  which was released in 1998!  I do see where you are going with your question,  and yes,  I would like some sort of upgradability ready to be tapped into at some point in the future.
As for $$$,  with my first child on the way (due in March),  I'm pretty much at my ceiling atm.  Now,  convince me otherwise (not a problem) and I can try to convince the other half as well (not so easy)....
Guest
Guest
  Quote rallymaster Quote  Post ReplyReply bullet Posted: 09 Nov 2007 at 11:38pm
? in regards to the PSU.  Will 620 W be sufficient for 2 8800GT's in SLI in the future?
Tyler:  to clarify,  $1500-$1600 is my budget for the initial purchase.  I'll be able to add/improve individual components in the future,  so I'm really asking for a suggestion for a good platform that can slowly be developed up to it's potential....
skyR View Drop Down
  Quote skyR Quote  Post ReplyReply bullet Posted: 09 Nov 2007 at 11:45pm
Yes 620W is enough for SLI 8800GT.
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 10 Nov 2007 at 12:01am
Ok, cool Smile.
I try and squeeze every last week of lifespan from my systems before replacing. I probably waited a bit long this last time (games from 1998 ran great on it though Tongue).
It'll be easier if we drop the SLi mobo. Both from the standpoint of the price of the motherboard itself, and from the standpoint of the PSU. If you don't have to plan for another GPU, your potential power needs go down, and so will the price.
How about this:
Power Supply: 520W Corsair HX (Dual SLI Compatible) (Silent Edition)
Memory: 2GB DDR2 Corsair at 800MHz XMS2 (Dual Channel) (Performance)
Floppy / Media: Sony 1.44MB Floppy (Black Edition)
Hard Drive 1: 250GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Modem: - No Thanks
Cooling: Air Cooled Stage 2 (Silent Artic Cooling Heat-sink (Copper Heatpipes)
This system comes in at $1469. I dropped the keyboard and mouse, as I figured you probably already have them, and they are easily purchased locally if you want a replacement at some point. If you want to add an LT motherboard, you could go SLi, but keep in mind that means pushing the price of the PSU up too, in which case I would recommend the 620HX.
You don't hear this one much, but I *love* my power supply. It's dead on with the voltages and has a unified 12V rail for graphics cards which means you don't have to panic over "can this rail push enough amps" later.
I also added the floppy to the build. I don't have a strong enough base in software to be 100% certain of this, but I was given to understand that XP needs a floppy as a boot device for some purposes. I am thinking it's BIOS flashing, but it may be something else. For $10 it seemed cheap insurance against the potential need, but you might wish to inquire of DSO whether or not what I have been told is correct.
If you are positive that you won't overclock later you could drop to 667 RAM. A 1333 FSB and 667 are synchronized. Their base speeds are the same. I believe that is a difference of $50 which is enough to cover the PSU upgrade. I won't tell you there is *no* difference in performance. There is, but it's not a significant difference, certainly not enough that I'd let it stand in the way of other things that are harder to upgrade later.
You could also drop the stage 2 cooling, but IMO, anything that helps a system run cooler and reduces wear and tear on the CPU is a very good long term investment. Even if you don't overclock it (say a couple years down the road, when the system is starting to show a little age, it might be nice to be able to push a little more muscle while you save for the next upgrade).
With the mobo change, and the psu change, if you drop the RAM down, you should be right around $1540-$1550. If you can convince the minister of finance that buying the RAM is worth going to ~$1590, you can have it all.
juggernaut View Drop Down
  Quote juggernaut Quote  Post ReplyReply bullet Posted: 10 Nov 2007 at 12:08am
Are the case lighting and second optical drive necessary?
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 10 Nov 2007 at 12:34am
That last bit about taking a while to reach full potential of the system has been stewing in my head while I've been looking through the forums. I took that approach and sacrificed on the GPU to go quad and upgrade the motherboard. I don't know how much such an option would appeal or not, but that is how I did things- bought the best I could afford when it came to components I was not going to want to mess with later, and saved on the stuff I knew I could handle myself as finances allowed. It is another option.
Guest
Guest
  Quote rallymaster Quote  Post ReplyReply bullet Posted: 10 Nov 2007 at 12:36am
Lighting, no.  but yes,  I need both a CD drive and a DVD-ROM (some of my sims are imports and need DVD ROM readability.
Do I understand correctly that 2 video cards in SLI can nearly double your performance,  whereas the most you might get out of a memory and processor upgrade might be 30%?  If so,  going SLI capable would insure me a good performance boost in the future for what could be really cheap by then as the 8800GT price comes down?  Am I off base with this thinking?  help :(
Thanx for the tip on the floppy.  I'll inquire.
Did I read somewhere that DS can add additional fans into cases?  Are the different stages of cooling upgrades easily upgraded and user friendly?
Thanx again,  you guys are a great help!
skyR View Drop Down
  Quote skyR Quote  Post ReplyReply bullet Posted: 10 Nov 2007 at 12:41am
Air stage 1 is stock heatsink
Air stage 2 is better heatsink
Air stage 3 is better heatsink + overclock
You gain about 15%-30% with SLI, not double.
You can request Digital Storm to add additional fans to the case if you like..
Guest
Guest
  Quote rallymaster Quote  Post ReplyReply bullet Posted: 10 Nov 2007 at 8:42am
noted....
thanx again!
Guest
Guest
  Quote rallymaster Quote  Post ReplyReply bullet Posted: 10 Nov 2007 at 10:00am
OK.  After tweaking my configuration around based on the many suggestions,  this is what I think I've fianlly settled on.
Total Price with Instant Savings: $1,567.00
Power Supply: 620W Corsair HX (Dual SLI Compatible) (Silent Edition)
Motherboard: nVidia 680i LT Core 2 Quad (By: eVGA) (nForce 680i SLI)
Memory: 2GB DDR2 Corsair at 667MHz (Dual Channel)
Modem: - No Thanks
Case Lighting: - No Thank
sr Manual: Personalized Platinum Digital Storm Binder (Includes Paperwork/Benchmarks/CDs/Manuals)
I'm sticking with SLI compatable just for future options,  and I understand that if I up the vid card(s),  I'll probably have to replace the PSU as well.  I don't have need for overclocking,  but I may want to in the future,  so I know that I'll have to upgrade the memory if I do so.
Barring any other hardware incompatabilities that you may pick up on,  I think this is what I'll be contacting the guys at DSO about.
John
Church View Drop Down
  Quote Church Quote  Post ReplyReply bullet Posted: 11 Nov 2007 at 1:21pm
make your sound card a tiny bit better, go with soundblaster audigy.. good price and good sound. use it on my old comp and it works just fine
  Quote Church Quote  Post ReplyReply bullet Posted: 11 Nov 2007 at 1:24pm
its really cheap too
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 11 Nov 2007 at 3:21pm
I think that config looks great. Anything else can be added in later with minimal headache.
Tybo View Drop Down
  Quote Tybo Quote  Post ReplyReply bullet Posted: 13 Nov 2007 at 3:34am
I agree with church 100%.  Choose the soundblaster audigy card.  Just my opinion but Realtek onboard sound stinks.  A inexpensive sound card will sound a lot better as well as increase overall performance a tad.
This page was generated in 0.1079102 seconds.
