Configuration Help for speed & gaming
Post Date: 2013-01-15
palolake View Drop Down
  Quote palolake Quote  Post ReplyReply bullet Topic: Configuration Help for speed & gaming
    Posted: 15 Jan 2013 at 11:08am
Need help with putting together a computer that is super fast and will play any game out there.  Tower will be in computer desk with a door.  Need good ventillation so as not to overheat.  If this is an issue, can sit on side of desk. Width of tower compartment is 10", Height is 22" and depth is 25".  Don't want to have to upgrade components for at least 3 yrs.  Don't need monitor, keyboard, mouse.  Budget up to 2500, but would prefer around 2000.  Sound also is important.  Have Harman Kardon Soundsticks.  Do not want Windows 8 at this time. Hopefully this is enough info to get some results.
Thanks, Bill
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 15 Jan 2013 at 11:39am
Hi palolake...  Welcome to the forums.
You didn't mention monitor size or resolution but for a single 23" at 1920x1080 anything with the gtx 670 or 680 will give you great gaming for a couple of years.
Lots of ways to go.  You should go to the config screens and see what hits you for a start.
For the $2000 .......
In general, for limited space, the Bolt level 4 will give you the best single card, the gtx 680.  But, I still wouldn't put it in a confined space even with the door open.  A good gaming rig needs room to breath
For top of desktop and the quietest, the Slade level one with a change to a gtx 670 would do it.
For tops in cooling and a great case, the Dreadnought level 1 with change to Gtx 670 is nice.
For the best bang for the buck, the ODE level 3 with the gtx 680, a SSD and HDD drives is tough to beat.
Hope this helps and good luck. Big%20Smile
Edited by bprat22 - 15 Jan 2013 at 11:42am
HockeyBuck View Drop Down
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 15 Jan 2013 at 12:11pm
Welcome palolake!
Another config possibility for that budget would be the Epoch 2...changed to Sabertooth mobo and a 1 TB hard drive. Ticket Number: 776047
  Quote palolake Quote  Post ReplyReply bullet Posted: 15 Jan 2013 at 1:26pm
Originally posted by HockeyBuck
Welcome palolake!
Sorry, thought I hit everything, but the monitor is 24" 1920x1200. I saved a configuration #776074, changed video card and added sound card.  What do you think?
Bill
BShizzleUniBrizzle View Drop Down
  Quote BShizzleUniBrizzle Quote  Post ReplyReply bullet Posted: 15 Jan 2013 at 2:48pm
Welcome to the forums palolake Awesome I'm not as of big of help as these guys are sorry, just wanted to welcome you. One thing I can and always will agree on is proper ventilation. Good luck! Strong
Cooler Master 942 HAF X
Core i7 3930K 3.2GHz/4.5GHz
16GB DDR3 1600MHz
3TB SATA
2x SLI GTX 680 4GB
Win 7 Pro x64
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 15 Jan 2013 at 2:53pm
Looks good.     HockeyBuck gave you a nice config to build on.
I personally would pick a better case with better cooling like the 500R with its side panel 200mm fan feeding air to the video card.
Nice rig and don't forget your free t- shirt.
BShizzle is right about proper ventilation.    Not to say tthe 300r won't work but under stress for hours more fresh air allows the video card to stay on lower fan speeds.
Edited by bprat22 - 15 Jan 2013 at 2:59pm
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 15 Jan 2013 at 3:05pm
You'll be fine with a single 1920 x 1200 24" display, but go as high as you can afford in graphics card choice to get best frame rates at that res, and you may make it 2-3 yrs before needing to upgrade.    When that time comes, one way to keep up would eventually be to add a second graphics card for SLI or Crossfire performance, and the Sabertooth board can handle that when its time.    Like most here on the DS Forums, I would recommend using a GTX 670 or a 680 over the 7970, unless you have a very strong preference for AMD cards.    Lots fewer problems and better overall performance in my opinion, but AMD has it's fans as well. Good build palolake!
Two more things on the current build...
1) In the 80's & 90's lots of "computer desks" had cubbyholes cut out for the computer chasis...a terrible thing for getting rid of heat generated by your components..    DS performance gaming rigs will perform best when not enclosed in that manner!    Heat buildup is a performance killer, and can shorten the life of your components as well... Place the chasis where it can get plenty of fresh cool air, and where it can get rid of the warm vented air from the exhaust fans.
2) The Epochs Corsair 300R chasis has additional fan mounts to use in the front, top, and two fan mounts on the window that will make a big airflow difference.    I usually recommend adding the fan upgrade to this case for best airflow for the GPU.
Don't forget to select your free game bundle, and the free DS T Shirt!
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 15 Jan 2013 at 3:22pm
My cohorts here on the forums always offer great advice!
One thing I forgot to mention about your build...The Asus boards these days have great 7:1 sound built in... Try it first, as you can always add a sound card later if it doesn't meet with your audio approval.    You can save the money on the added sound card, perhaps put it into the graphics card choice or a fan upgrade.
  Quote palolake Quote  Post ReplyReply bullet Posted: 16 Jan 2013 at 8:41am
  Quote palolake Quote  Post ReplyReply bullet Posted: 16 Jan 2013 at 8:44am
Big%20SmileThanks for all the help everyone.  Here is my config: 776398.  Is the power supply sufficient?  If ANYONE has a great build for me, please give me a configuration number because this can become mind numbing.
Thanks, Bill
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 16 Jan 2013 at 9:18am
That's a real nice config.  A quality case, motherboard, and gtx680.
Not to confuse you but here's another config to consider.  It's pretty close to yours but I put in the HafX case, the best air cooled case here.  It's a little bigger but is built solid, and the larger slower moving fans are quieter than smaller high reving fans.  Has other features as well if you click on the info.
I also changed from gtx 680 to the gtx 670.  It saves $150 and gives performance within 5-10% of the 680.  The 680 is great, so your call.  Here's a link comparing the 2 cards.
The other change is the cpu cooler.  The much smaller Vortex 120 is popular, takes up less room and has a good reputation, but the Noctua D14 is quiet and very reliable.  Not much to go wrong with a big block of cooling fins.
Config # 776408       Cost $ 2239
Hard Drive Set 1: Operating System: 1x (120GB Solid State (By: Corsair) (Model: Neutron GTX Series) (SATA 6Gbps)
Video Card: 1x NVIDIA GeForce GTX 670 2GB (Includes PhysX)
Game: FREE NVIDIA Bundle - Assassins Creed III (Digital Download Code for all GeForce GTX 600 Series)
Your latest build is a nice rig with great performance.  Mine just tweeks a few items.
One other way you can save $180, is to go with the 3570k cpu.  It is all gaming will use. But, the 3770k is a bit faster for multi-tasking, etc.
I didn't show a Dreadnought HafX config at first because of the space issue, but it isn't much larger than what we've been looking at.
Just another way to go.  Either rig will make you more than happy.  Big%20Smile
Edited by bprat22 - 16 Jan 2013 at 9:57am
  Quote palolake Quote  Post ReplyReply bullet Posted: 17 Jan 2013 at 4:53am
Thanks for all the help.  Will be ordering your suggestions in about 3 weeks.
Bill
