Configuration help please
Post Date: 2010-07-03
Taff View Drop Down
  Quote Taff Quote  Post ReplyReply bullet Topic: Configuration help please
    Posted: 03 Jul 2010 at 3:42am
Hoping to take advantage of the special this weekend so would appreciate some feedback. I'm thinking that I'll go with a 750W power source. Thanks and without further ado:
Motherboard: ASUS Rampage III Extreme (Intel X58 Chipset) (Supports Triple SLI or CrossFire)
System Memory: 6GB DDR3 2000MHz GTX-8 Digital Storm Certified Extreme Performance (Highly Recommended) (Hand Tested
Hard Drive Set 1: Operating System: 1x (128GB Solid State HOT SELLER  (By: Corsair) (Model: CMFSSD-128GBG2D) (Highly Recommended)
Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar Black WD1002FAEX  (7200 RPM) (64MB Cache) (SATA) (Extreme Speed)
Video Card: 1x ATI Radeon HD 5970 2GB
Add-on Card: !CLEARANCE HOT SELLER: BFG High-Performance Dedicated Ageia PhysX Card P1 128MB
Sound Card: Creative Labs X-Fi Titanium Fatal1ty Champion (Includes Front I/O) (PCI-Express Slot Based)
Noise Reduction: Noise Suppression Package (Optimized Airflow & Fan Speeds with Noise Dampening Material)
Warranty: FREE PROMO: Life-time Expert Customer Care with 3 Year Hassle-free Hardware Service
rholyrag View Drop Down
  Quote rholyrag Quote  Post ReplyReply bullet Posted: 03 Jul 2010 at 8:00am
Welcome to the forums Taff!
What is your budget and what resolution will you be gaming at?
rodsmith View Drop Down
  Quote rodsmith Quote  Post ReplyReply bullet Posted: 03 Jul 2010 at 9:50am
that will be a nice rig Taff,but I recommend you stay with the 1000w power supply,incase you decide to get another video card later to run sli
Taff View Drop Down
  Quote Taff Quote  Post ReplyReply bullet Posted: 03 Jul 2010 at 11:55am
Resolution is 1680 x 1040
Budget, up to 5thousand, less is better :)
Liq View Drop Down
  Quote Liq Quote  Post ReplyReply bullet Posted: 03 Jul 2010 at 12:13pm
you won't spend nearly half that if you're only gaming at 1680x1050 unless you like wasting money. Have you thought about getting a higher resolution monitor?
Taff View Drop Down
  Quote Taff Quote  Post ReplyReply bullet Posted: 03 Jul 2010 at 2:28pm
I have actually and would really like too, but I have a hubby, who is insistent that I don't need a larger monitor lol
OK, so what do you propose if I have limitations on monitor size?
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 04 Jul 2010 at 10:56pm
welcome to the forums :)
you dont have to have a huge monitor, if your res works for you, stick with it.
if you wanted a higher res, however, it doesnt have to come in a huge package... what monitor, exactly, are you currently using?
theres little reason to go over 2500 unless you have pretty specific needs, check this out as a good building block for a cool and quiet beast. you were not too specific in your needs, so i just went for an all purpose ass kicker
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 04 Jul 2010 at 11:32pm
I think !ender meant to pick win7 64bit and not the 32bit that is in his build, but he has a good build.
I like this one myself:
Here you go Ticket# 420033 --- Price: $2576 (To see this build click here) Price after current promotion $2576
Motherboard: EVGA X58 FTW3 Edition 3X SLI (Intel X58 Chipset) (Supports SLI or CrossFire)
Hard Drive Set 1: Operating System: 1x (80GB Solid State (By: Intel) (Extreme Performance) (Model: X25-M MLC Edition)
Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar Black WD1001FALS (7200 RPM) (32MB Cache) (SATA) (Extreme Speed)
Video Card: 1x NVIDIA GeForce GTX 470 1.2GB (Includes PhysX Technology)
Sound Card: Creative Labs X-Fi Titanium Fatal1ty Professional (PCI-Express Slot Based)
