Configuration Help
Post Date: 2020-08-04
tworattle View Drop Down
  Quote tworattle Quote  Post ReplyReply bullet Topic: Configuration Help
    Posted: 04 Aug 2020 at 10:51am
$2,500 (have flexibility though)
A lot of the games I play are fairly processor intensive, but I still want to be able to play them with the graphics turned up.
Typically will be for gaming and home use (internet, excel for budgeting, etc.). I play mostly grand strategy games by Paradox such as Hearts of Iron 4, Crusader Kings 2, Stellaris. I will also occasionally play Total War titles.
None
Saved Ticket #:
3294915
https://www.digitalstorm.com/configurator.asp?id=3294915
Chassis Model: Digital Storm Lynx
Processor: Intel Core i7-10700K (5.1 GHz Turbo) (16-Thread) (8-Core) 3.8 GHz
Motherboard: ASUS ROG MAXIMUS XII HERO (Wi-Fi) (Intel Z490 Chipset) (Up to 3x PCI-E Devices) <br><strong></strong>
System Memory: 16GB DDR4 3000MHz Corsair Vengeance RGB Pro (RGB Light Bar) <br><strong></strong>
Power Supply: 850W Corsair / EVGA / Thermaltake (Modular) (80 Plus Gold) <br><strong></strong>
Optical Drive: - No Thanks
Storage Set 1: 1x SSD M.2 (1TB Seagate FireCuda 520) (NVM Express) (Gen4 PCIe) <br><strong></strong>
Storage Set 2: - No Thanks <br><strong></strong>
Graphics Card(s): 1x GeForce RTX 2060 6GB (VR Ready)
Extreme Cooling: H20: Stage 2: Digital Storm Vortex Liquid CPU Cooler (Dual Fan) (Fully Sealed + No Maintenance) <br><strong></strong>
Cable Management: Exotic Cable Management - Black - (Cable Combs with Custom Color Sleeved Extension Cables) <br><strong></strong>
Chassis Fans: Digital Storm Performance Series (RGB Fans)
Airflow Control: - No Thanks
Boost Processor: Stage 1: Overclock CPU - Up to 4.7GHz on All CPU Cores <br><strong></strong>
Boost Graphics Card(s): Yes, Overclock the video card(s) as much as possible with complete stability <br><strong></strong>
Mouse Pad: - No Thanks
Branded Gear: - No Thanks
Priority Build: - No Thanks, 6 Week Ship Estimate After Order Is Successfully Processed
John18 View Drop Down
  Quote John18 Quote  Post ReplyReply bullet Posted: 04 Aug 2020 at 12:02pm
Two things sticks out to me.
You can save money by downgrading the motherboard unless you have a reason for it.
Also, your configuration has just one storage device, the 1TB Firecuda. I suspect that Cretae will come in and suggest the 520GB Firecuda and add a 2TB HDD for storage. However if you have a drive at home that you plan on adding as an additional drive, then that would make sense for your current storage configuration.
  Quote tworattle Quote  Post ReplyReply bullet Posted: 04 Aug 2020 at 2:22pm
I actually do not have a specific reason for the motherboard other than I didn’t like the astetics of the board it came with and a vague understanding that a quality motherboard is important (I’m sure the included option is better quality than what you would get from Alienware or anywhere like that).
I do not have another drive that I would use. So I am comfortable switching to the 500GB Firecuda and doing the included 2TB storage drive.
I updated my build with your suggestions and came out with the below. I added a 2070 since the other changes would bring me below my budget including that.
3295436
https://www.digitalstorm.com/configurator.asp?id=3295436
Motherboard: ASUS TUF GAMING Z490-PLUS / MSI MPG Z490 GAMING EDGE (Intel Z490) (Up to 3x PCI-E) (No SLI) <br><strong></strong>
Storage Set 1: 1x SSD M.2 (500GB Seagate FireCuda 520) (NVM Express) (Gen4 PCIe) <br><strong></strong>
Graphics Card(s): 1x GeForce RTX 2070 SUPER 8GB (VR Ready) <br><strong></strong>
  Quote John18 Quote  Post ReplyReply bullet Posted: 04 Aug 2020 at 3:18pm
Two more things.
It is generally recommended by most here to do NOT overclock the GPU. Only let them overclock the CPU.
Second, do you plan on using this rig in a 1440p environment? If the answer is no then you can go back to the 2060 SUPER. If, however, the answer is yes then the 2070 SUPER will be great now, or a few years from now.
Good luck.
  Quote tworattle Quote  Post ReplyReply bullet Posted: 04 Aug 2020 at 3:32pm
I currently have a 27inch 1080p monitor that I’ll most likely be keeping for awhile as I got in in February when my monitor I had for 10 years finally died. I could always upgrade the video card in the future if I upgrade my monitor. I’ll drop it back down to a 2060 Super and drop the OC on the GPU.
3295634
https://www.digitalstorm.com/configurator.asp?id=3295634
Graphics Card(s): 1x GeForce RTX 2060 Super 8GB (VR Ready) <br><strong></strong>
Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) <br><strong></strong>
Edited by tworattle - 04 Aug 2020 at 3:37pm
  Quote John18 Quote  Post ReplyReply bullet Posted: 04 Aug 2020 at 6:58pm
Works for me. Let Cretae look at in in the early morning and see what he says about it.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 05 Aug 2020 at 4:43am
John18 has steered you to the optimal price/performance build for 1080p gaming!
I like the smaller NVMe SSDs simply because that's the drive you will scan regularly for viruses, malware, adware, etc. Those scans will execute mostly in under 2 minutes on a compact NVMe, and I find that GLORIOUS after 35 years of enduring slow as molasses scans that could run up to 20 minutes or more. It also allows for faster back-ups of the whole primary drive. All this, to me, means I am more willing and able to keep my primary drive in top condition with a contemporary back-up should things go sideways.
We don't favor the GPU overclock because more heat means the fans work more often, and on some GPUs, they are quite loud. The performance bump isn't all that much. Wise move to drop the 2070. The last thing you want to do is overspend there with a new line of more powerful cards arriving soon. The RTX 2060 SUPER is the top card for 1080p.
