Configuration problem
Post Date: 2019-01-21
sunnyrose1994 View Drop Down
  Quote sunnyrose1994 Quote  Post ReplyReply bullet Topic: Configuration problem
    Posted: 21 Jan 2019 at 6:22pm
Hi. This is my current computer and I would like to upgrade it to a standard 2015 gaming rig.I did upgrade my video card to Nvidia gtx 980 Ti and 16 gig of ram. I need advice on a Motherboard, CPU, Cooling system and anything else if needed.I mostly use it for gaming and I want to be able to run any games on Max settings. Thank you.
Open Budget but I don't need to ovespend on uneeded components.
Power Supply: 1200W Corsair Pro Gold Series (CMPSU-1200AX) (Dual/Triple/Quad SLI Compatible)
Hard Drive Set 1: Operating System: 1x (120GB Solid State (By: Intel) (Model: 320 Series SSDSA2CW120G3K5)
Video Card(s): 2x SLI Dual (NVIDIA GeForce GTX 570 1.2GB (Includes PhysX Technology)
CPU Boost: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires Pro or Deluxe Series Motherboard)
Memory Boost: Memory Fan Kit Only (Does not include memory overclocking service)
Psyoshi View Drop Down
  Quote Psyoshi Quote  Post ReplyReply bullet Posted: 21 Jan 2019 at 6:48pm
2015 is a bit in the past. Max setting but what resolution? If you are talking 4k 120fps, you will need a very high end monitor and dual 2080ti SLI. 1440p 144fps a 2070 does fine, 2080 a bit better and 2080ti solo can hit 60-70fps in 4k. The 2070 is current best price/performance.
Edited by Psyoshi - 21 Jan 2019 at 6:49pm
  Quote Cretae Quote  Post ReplyReply bullet Posted: 22 Jan 2019 at 5:38am
As he said, the screen resolution you're going for is the key to your build.
  Quote Psyoshi Quote  Post ReplyReply bullet Posted: 22 Jan 2019 at 8:42am
For ~$2000 the vanquish 7 level 4 is probably the best deal out there for your upgrade. Your PSU, idk what connectors it has or not, modular or not, but it can be swapped in if it has the proper connectors. For the most part everything else needs upgraded and as for overclocking.... Intel and AMD have traded places on being fireballs, so a water cooler is a must if you plan to overclock.
This page was generated in 6.811523E-02 seconds.
