Configure LED lights?
Post Date: 2018-08-01
nosynths View Drop Down
  Quote nosynths Quote  Post ReplyReply bullet Topic: Configure LED lights?
    Posted: 01 Aug 2018 at 1:05pm
Hello,
I'm wondering if there is a way to reconfigure the LED lights on my tower. I have the Vanquish 1. The default configuration seems to be a rainbow effect going around the around the sides and bottom, I'm hoping to adjust this to a solid color or maybe a two color effect without the rainbow.
Thanks
  Quote Cretae Quote  Post ReplyReply bullet Posted: 01 Aug 2018 at 1:47pm
Look for the remote that controls it in the box of extra gear that came with your computer. It's not obviously a remote as it comes packaged in one of those anti-static envelopes. There are instructions with it. if you didn't get one, you'll have to ask DS to send it.
You can program a solid color if you want to.
  Quote nosynths Quote  Post ReplyReply bullet Posted: 01 Aug 2018 at 2:39pm
Thank you for the reply. I found the remote, I totally forgot it came in the box. Thanks again!
  Quote Cretae Quote  Post ReplyReply bullet Posted: 02 Aug 2018 at 5:41pm
Glad to help.
Good luck.
This page was generated in 2.636719E-02 seconds.
