Congifguration help?
Post Date: 2008-12-28
manheim View Drop Down
  Quote manheim Quote  Post ReplyReply bullet Topic: Congifguration help?
    Posted: 28 Dec 2008 at 10:01am
I am trying to make a gaming pc for mostly fps, and mmo's. Nothing fancy just want something solid and dependable. I was hoping for something in the $1700-1800 range. I am not sure what resolution i think its a 22 inch lcd with about 1600x 1024? I have the monitor , mouse, and keyboard.( com pany wiht great supportmy last computer just died and the company wont help me trouble shoot it anymore) . I was torn between core 2 and quad core?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 28 Dec 2008 at 12:55pm
wait a bit new GPUs are coming out which should drop the prices on current GPUs.
for that resolution to play at high settings you need 2 GPUs, but your price is not letting us do that.
I can config a dual core or an old quad core, but this PC can be upgraded to be more powerful and you can update to the next round of CPU down the road, tell me what you think, remember the price should be a bit lower when the new GPUs come out.
here you go Ticket# 221225 --- Price: $2094 (To see this build click here)
System Memory: 3GB DDR3 1333MHz Corsair Dominator DHX (High-Performance)
Power Supply: 750W Corsair TX (Dual SLI Compatible) (Silent Edition)
Card Reader: - No Thanks
Hard Drive Set 1: Operating System: 500GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Video Card: 1x NVIDIA GeForce GTX 260+ 896MB (216 Streams) (Includes PhysX Technology)
LCD Display: - No Thanks
Priority Build: - No Thanks
now remember you get an additional $100 of the price listed above right now due to the special they have going.
upgrades down the road can be adding another 3GB of ram, upgrading HDD to veloci raptor, adding a second 260+ gtx, etc.
Edited by DST4ME - 28 Dec 2008 at 12:56pm
  Quote manheim Quote  Post ReplyReply bullet Posted: 28 Dec 2008 at 4:20pm
Okay so i should go with the new I7? I like this build and was just worried about getting too far ahead of games.
Thank you very much for the configuration ideas. I would love to have something like this. The other thought i had was water cooling. It seems like the i7's run hot and get more from water cooling or is that something i would never need?
I dont think i want to watercool the gpu's but i thought about WC for the cpu to help overclock it?
Never had a watercooled rig before is that a lot of work?
Sorry for all the questions. Thank s in advance for any help.
Dsnewb210 View Drop Down
  Quote Dsnewb210 Quote  Post ReplyReply bullet Posted: 28 Dec 2008 at 4:29pm
I would go with an I7 setup because you will have to get a x58 mobo and that will in turn give you upgradeability.
As for getting ahead of games i wouldn't worry about that, it just future proofs your system even more.
The I7 is fine with air, infact ive seen alot of people hit 3.6-4.0 stable on air.
Liquid cooling is great and sometimes leads to higher oc's, however you must add liquid every 3-5 years.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 28 Dec 2008 at 5:19pm
LC is great IMO, but the stage 2 air is doing great here also. personally I prefer LC but you need to decide for yourself. but if you do choose LC then do the cpu only.
LC is no work, once every month or two you may need to put a bit of liquid in there, which is very easy. other then that, every 3 to 5 years you might want to change the liquid.
You are very welcome and feel free to ask as many questions as you like.
Edited by DST4ME - 28 Dec 2008 at 5:19pm
