Connection lag when CELL phone rings.
Post Date: 2010-03-24
jp619 View Drop Down
  Quote jp619 Quote  Post ReplyReply bullet Topic: Connection lag when CELL phone rings.
    Posted: 24 Mar 2010 at 6:27pm
Ok so my connection has started doing this for the past 2-3 days now.
Every time my cell phone rings, I get HUGE lag spikes, my ping jumps from like 30s to 2000s or more. It drops me from whatever game i am playing online, it gets me really frustrated Sleepy
My router is a Netgear wireless G-router WGR614V9, but my computer is wired connected.
Any ideas why it does this?
-------Sorry if this doesn't belong here, looked through the others, and it seemed this might fit in this section---------
Edited by jp619 - 24 Mar 2010 at 6:28pm
Exsidium View Drop Down
  Quote Exsidium Quote  Post ReplyReply bullet Posted: 24 Mar 2010 at 6:31pm
try taking the router out of the circuit and see if you have the same result.. That's weird though.  No way and I mean no way a cell phone should interfere with a wired machine.
  Quote jp619 Quote  Post ReplyReply bullet Posted: 24 Mar 2010 at 6:34pm
I am sorry, but I am umm, how do i put it...bad? :P When it comes to this, what do you mean by "circuit", unplug it?
MyNameisBrian View Drop Down
  Quote MyNameisBrian Quote  Post ReplyReply bullet Posted: 25 Mar 2010 at 1:17am
I think he means try connecting your computer directly to the modem, so you are not using the router.
If it stop doing it, then you know its the router.
