Considering purchase few questions
Post Date: 2021-12-08
bobaz View Drop Down
  Quote bobaz Quote  Post ReplyReply bullet Topic: Considering purchase few questions
    Posted: 08 Dec 2021 at 9:00am
Hi,
With a I9 12th Gen CPU, 390 GPU, DDR 5 memory, & several peripherals, is a 850W PS sufficient ?
Would their be a tremendous difference between a "GeForce RTX 3090 24GB Founders Edition", & "GeForce RTX 3090 24GB Performance Edition" for a an additional $600?  Also, I don't see a manufacturers name listed.
I never heard of the H20: Stage 2: Digital Storm Vortex Liquid CPU Cooler (Dual Fan) (Fully Sealed + No Maintenance) that's offered.  What's a stage 2?  Size of fans?  Can it be substitued for another brand?
TIA for any comments.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 09 Dec 2021 at 5:04am
I think you'll be fine, but look for yourself:
https://outervision.com/power-supply-calculator
The 3090 is not a good card for gaming. The 3080 Ti is a better choice.
https://gpu.userbenchmark.com/Compare/Nvidia-RTX-3080-Ti-vs-Nvidia-RTX-3090/4115vs4081
All PC builders are supplying whatever they can get from the broken supply chain. Naming the parts you might get isn't likely these days.
Stage 2 refers to dual fans. They are 120mm. The word we have is thta DS buys there AIOs from the same factory Corsair uses. They don't make their own fans, either. Both companies just put their own brand on them.
IDK if you can order another kind. It used to be doable for an extra fee, but these are different times. IMHO it's pretty unnecessary. You'll pay more, delay the build, and for what? It's not in DS's interest to use cheap parts they have to stand behind. An AIO isn't rocket science and many sellers don't make their own anyway.
  Quote bobaz Quote  Post ReplyReply bullet Posted: 09 Dec 2021 at 6:16am
Thank you sir, very helpful.  3080 ti over 3090 surprises me cus 3090 has 2x the memory.. confusing
Edited by bobaz - 09 Dec 2021 at 6:31am
MrCheetah View Drop Down
  Quote MrCheetah Quote  Post ReplyReply bullet Posted: 09 Dec 2021 at 11:47am
You could scrape by, however, a 1000 W power supply would be best.
Intel Core i9-12900K NVIDIA GeForce RTX 3090 (example) | OuterVision PSU Calculator
Probably not $600 difference. In actual usage, the graphics card will rarely push beyond the 350 W threshold (limit of dual 8-Pin PCIe connectors). In the Forza Horizon 5 benchmark below, you can see a 350 to 400 W usage, but that's with a card being pushed quite a bit. My 3090 FTW3 Ultra can maintain 2010 MHz GPU + 9700 MHz VRAM and not break 340 W. I did utilize EVGA's Precision X1's VF Curve Tuner to achieve that -- essentially by undervolting. So, the "Performance" cards would only be of any benefit if you intend to push them to the absolute edge. One more thing... Marketed boost values, whether by Nvidia or third-party board producers, are safe/minimum values. Most cards will automatically (i.e., default/stock settings) go beyond.
Also, this next answer:
A better value for gaming.
The 3080 Ti GPU bin is technically only ~2.5% less capable than the 3090.
Nvidia RTX 3080 Ti Vs RTX 3080, RTX 3090 And RX 6900 XT: Which should You Buy? | Forbes
Additionally, unless you're also springing for an 8K monitor, games do not require more than 12GB of VRAM, most don't even surpass 10GB of usage.
Cyberpunk 2077 - RTX 3090 ( 4K & 8K ) | Testing Games (YouTube)
Microsoft Flight Simulator 2020 - RTX 3090 - i9 10900K | Jansn Benchmarks (YouTube)
Forza Horizon 5 Extreme Settings - Ray Tracing - 4K - RTX 3090 - Ryzen 9 5950X | Bang4BuckPC Gamer (YouTube)
Shadow of the Tomb Raider - 4K - RTX 3090 - i9 9900K | Jansn Benchmarks (YouTube)
Originally posted by Digital Storm
Digital Storm will use a top brand name graphics card from the likes of ASUS, EVGA, PNY, MSI, etc... An example would be the ASUS TURBO series.
Source: Graphics Card(s) More Info link
@Cretae
Edited by MrCheetah - 09 Dec 2021 at 2:14pm
  Quote bobaz Quote  Post ReplyReply bullet Posted: 09 Dec 2021 at 1:55pm
Good stuff, thank you very much.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 10 Dec 2021 at 3:30am
It gives us pleasure to perhaps dispel misunderstanding with accurate information. The decision is always up to you, but we hope to make it an informed one.
HockeyBuck View Drop Down
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 27 Dec 2021 at 12:31am
Keep in mind bobaz that if you can wait and can afford the price DS can get it for... and a particular branded part IS AVAILABLE on the current crazy supply market...DS can & will order whatever you want used for your build. You do have to ask DS Sales what's possible, but DS will build the rig you want.
