Constant low fps in games and slow loading
Post Date: 2024-02-08
Jaxmadax View Drop Down
  Quote Jaxmadax Quote  Post ReplyReply bullet Topic: Constant low fps in games and slow loading
    Posted: 08 Feb 2024 at 3:29pm
My lynx Pc has been having issues for a while now. I have high FPS in cutscenes or videos but when I'm playing a game, they drop to sometimes 1 FPS. Is there any way I can fix this?
I have AMD Ryzen 5 5600G with Radeon Graphics
  Quote Snaike Quote  Post ReplyReply bullet Posted: 08 Feb 2024 at 4:37pm
Originally posted by Jaxmadax
.... Is there any way I can fix this?
Im not one of the smart people around here but it seems to me that if you're using your mobo for graphics you need to get a GPU or you're going to have issues with even the older potato games.
Let's wait till The Smart Guys® check in. I'm usually wrong on these things.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 13 Feb 2024 at 5:31am
A discrete video card is your answer. Your CPU and motherboard are more than adequate for a very decent GPU. Just be sure you get one that does not need more power than your supply can provide. I have seen the Nvidia RTX 3060 recommended to pair with your CPU, and it only requires 550-600W power supply. The 4060 also would serve you, but it may be pricier. If you are daunted by installing your own, (which is not that difficult, you may have a friend who has done it) then go to Best Buy or somewhere to purchase where they can install it for you.
These cards should run in the $300 range and will kick-a at 1080p monitor resolution.
Edited by Cretae - 13 Feb 2024 at 5:34am
This page was generated in 1.855469E-02 seconds.
