Control Panel SettingsPost Date: 2014-07-25 |
Author | ||
Clay
Senior Member Joined: 11 Apr 2009 Online Status: Offline Posts: 526 |
Topic: Control Panel Settings Posted: 25 Jul 2014 at 8:50pm |
I have my Dual 780's setup now. Its been over a month since Ive last played any games.
What settings do I use in the Nvidia control panel? SLI runs great in all my games as far as I can tell. Thanks for the input!! |
I7 13700KF 5.4hz
ASUS Prime z790 MoBo ASUS Dual 4070 32g ram@5200 850 Gold PSU 1TB SSD 2TB SSD 27" ASUS Monitor 144hz Razer Ornata Chroma Keyboard Razer Basilisk V2 Mouse Nari Ultimate Headset |
Meller
Quote Reply Posted: 25 Jul 2014 at 11:46pm | |
You're going to have to be more specific. What settings for what? What are you trying to change/fine tune?
Custom PC
Clay
Quote Reply Posted: 26 Jul 2014 at 12:49am | |
Not sure to be honest... this is my first SLI setup. What do you have yours set at if I may ask? Computer specs are below.... what should my settings be at?
I7 13700KF 5.4hz
Meller
Quote Reply Posted: 26 Jul 2014 at 1:16am | |
Haha, what do I have what set as? I mean, DS should have enabled SLI for you and everything before they sent you your PC. So you shouldn't have to set that up... Otherwise, I'm unsure which specific setting(s) you're referring too.
Real talk though, as long as you have SLI enabled... you can leave Physics or whatever nvidia calls it to auto... and everything will be fine. |
Custom PC
Clay
Quote Reply Posted: 26 Jul 2014 at 4:26am | |
Sighs
The control panel stuff... - "Manage 3D settings" That area... |
I7 13700KF 5.4hz
redsoxfanatic
Groupie Joined: 19 Sep 2011 Online Status: Offline Posts: 161 |
Quote Reply Posted: 27 Jul 2014 at 8:29pm | |
You shouldnt have to change any of the entries in "Manage 3D settings". Its typically something for more advanced users (ie tweaking graphical settings that arent available natively in-game). The nVidia Control Panel should automatically set the optimal settings for each program/game you use.
Edited by redsoxfanatic - 27 Jul 2014 at 8:30pm |
Clay
Quote Reply Posted: 28 Jul 2014 at 3:40am | |
Ok... so i should put it back to default? lol
I7 13700KF 5.4hz
PcKiller
Groupie Joined: 17 Jun 2014 Online Status: Offline Posts: 446 |
Quote Reply Posted: 28 Jul 2014 at 7:46am | |
Clay, do you play Skyrim at all?
I-5 14600 KF
ASUS Prime Z790-P D5 32GB DDR5 6000MHz Kingston FURY Beast RGB SSD M.2 2TB Samsung 990 PRO RTX 4080 16GB H20: Stage 3: Digital Storm Vortex Liquid CPU Cooler Asus PB278Q 27" 2560 by 1440 |
Clay
Quote Reply Posted: 28 Jul 2014 at 3:36pm | |
nope... play Ghost and BF4 for now. Just received Titan Fall as one of my free games... installing as we speak
I7 13700KF 5.4hz
Clay
Quote Reply Posted: 28 Jul 2014 at 3:37pm | |
Thanks for the feed back guys!! Mucho appreciated!!
I7 13700KF 5.4hz
StealthG6
Newbie Joined: 13 Jul 2014 Online Status: Offline Posts: 77 |
Quote Reply Posted: 28 Jul 2014 at 5:03pm | |
I'm pretty sure with SLI that DS does for you is more a long the lines of "set it and forget it."
How many games have your tried with your SLI setup?
I actually do, I don't have my computer yet does SLI work good on it?
Apollo
i5 4690K 3.50 GHz (Codename Devils Canyon) 16GB DDR3 1600MHz 2x Asus GTX 770 DirectCU II 4GB GIGABYTE G1.Sniper Z97 H20: Stage 2: Corsair H110 280mm Radiator |
Clay
Quote Reply Posted: 28 Jul 2014 at 5:12pm | |
SLI works on all the games so far. Ghost / BF4 / Titan FAll
I7 13700KF 5.4hz
StealthG6
Quote Reply Posted: 28 Jul 2014 at 5:55pm | |
^ Sounds good, I can't wait to try mine on Skyrim and Total War Rome II.
Apollo
Clay
Quote Reply Posted: 28 Jul 2014 at 6:19pm | |
SLI Enabled
Unigine Heaven Benchmark: 97.0 FPS. Settings: API DX11 Quality: Ultra Tesselation: Extreme Stereo 3D: disabled Anti-aliasing: x8 Fullscreen at 1920x180 Edited by Clay - 28 Jul 2014 at 6:20pm |
I7 13700KF 5.4hz
Clay
Quote Reply Posted: 05 Aug 2014 at 5:53pm | |
Quick question... 80c considered overheating when SLI enabled?
I7 13700KF 5.4hz
PcKiller
Quote Reply Posted: 05 Aug 2014 at 6:11pm | |
I have to play Skyrim in window mode for it to be in SLI |
I-5 14600 KF
Clay
Quote Reply Posted: 05 Aug 2014 at 6:18pm | |
Played BF4 and Ghost. Runs Great!!! Just wondered about the 80c is all...
I7 13700KF 5.4hz
Quote Reply Posted: 06 Aug 2014 at 3:03am | |
Until PcKiller comes back...... His rig has the sli 780's water cooled and running a lot cooler than air cooled cards would be.
Clay
Quote Reply Posted: 06 Aug 2014 at 3:42am | |
Yup...I'm good tho bprat. I dont run games that often, and I put the computer to sleep after 30 minutes anyways
I7 13700KF 5.4hz
PcKiller
Quote Reply Posted: 06 Aug 2014 at 6:57am | |
Here is the temps chart for Skyrim with everything on maxed out. In SLI, as you can see from the chart, the temp goes no higher than 42C. Hope this helps, If needed, I could make charts of other games I have for you. And the rez was 2560 by 1440. Edited by PcKiller - 06 Aug 2014 at 7:05am |
I-5 14600 KF
Clay
Quote Reply Posted: 06 Aug 2014 at 3:41pm | |
problem solved... wow. I have system mechanic... and one of the features is this thing called "Live Boost". It basically makes certain things on your computer go faster, high performance, etc. Well, long story short. I disabled it and now my temps are around 65ish. Titan Fall runs at 53c now (weird). Anywho, I also adjusted some stuff within the controal panel (youtubed it) that helped as well.
Thanks for all the input guys! |
I7 13700KF 5.4hz
PcKiller
Quote Reply Posted: 06 Aug 2014 at 4:52pm | |
That program sounds like it was slowing the GPU fan down some.
I-5 14600 KF
Clay
Quote Reply Posted: 06 Aug 2014 at 5:23pm | |
No idea.... things are running better during game play. Uni gin Heaven Benchmark still takes it to 80c still
I7 13700KF 5.4hz
