Control Panel
Post Date: 2008-12-03
madmxe View Drop Down
  Quote madmxe Quote  Post ReplyReply bullet Topic: Control Panel
    Posted: 03 Dec 2008 at 2:50pm
 All of a sudden Control Panel will not open on,,64 bit Vista installed. Some other odd things aren't working either, some games,,external HD..
 A web search shows this is a problem and I have tried a couple of the fixes but they havent worked. Anyone have this problem? Any suggestions out there?
Thanks,,and the DS PC I bought is great.
  Quote madmxe Quote  Post ReplyReply bullet Posted: 03 Dec 2008 at 5:32pm
I have a Q9650 3ghz OC to 3.38.
A GTX280 card.
I have gotten an occasionally boot up error,,System is in Safe Mode, Please reset CPU or memory.
I called DS and we played with it and it went away. I have received that message a couple of times since I have called them but then it boots up fine and I assume is ok. A google search of the problem shows several causes that others have had with it. Nothing really makes much sense to me though.
Thanks
jtspectra2 View Drop Down
  Quote jtspectra2 Quote  Post ReplyReply bullet Posted: 03 Dec 2008 at 9:40pm
Hey buddy, i hope that you get your problem fixed as soon as possible. I was just curious though
is that 3.38 the OC that came from DS ??
  Quote madmxe Quote  Post ReplyReply bullet Posted: 03 Dec 2008 at 11:07pm
 Yes,,its DS.
This page was generated in 5.957031E-02 seconds.
