Controlled Advanced LED Lighting System
Post Date: 2018-11-12
KuldeepM View Drop Down
  Quote KuldeepM Quote  Post ReplyReply bullet Topic: Controlled Advanced LED Lighting System
    Posted: 12 Nov 2018 at 12:10pm
Hello all, I come to you with I hope a simpler question. I was curious if there was a way to set the LED in my PC to a certain color besides red, blue, green, or white. Is there an program on my PC that I am supposed to use, or is it completely controlled through the remote. It also seems to reset to the default rotating RGB whenever I restart.
Thank you!
... removed ad. Consider this "Warning issued" ...
Edited by Snaike - 14 Nov 2018 at 11:28am
  Quote Cretae Quote  Post ReplyReply bullet Posted: 13 Nov 2018 at 10:47am
I'm pretty sure the single color is limited to those four. Here's how to keep a particular setting after you power off:
Remote Control
MODE -> LOCK -> POWER (OFF) --> POWER (ON)
* above POWER refers to remote power button not system power button
Once I perform those sequences on a power cycle the RGB settings hold.
Hope it works for you!
