Cooler Master cpu rgb
Post Date: 2019-11-01
maldayven View Drop Down
  Quote maldayven Quote  Post ReplyReply bullet Topic: Cooler Master cpu rgb
    Posted: 01 Nov 2019 at 2:07pm
I just recently got my new pc, and it came with a Cooler Master Vortex cpu cooler that has RGB lighting. Is there a way to control the RGB lighting with the entire cooler? I have RGB throughout the entire setup controlled by the controller, but with the cpu cooler block and fan running on its own, completely different rgb faze, it really puts off the effect.
HockeyBuck View Drop Down
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 01 Nov 2019 at 3:30pm
Welcome to the forum maldayven!
If the RGB fan is also a Cooler Master model, there may be a wired little push button control box attached on a cable for the RGB choices.   If not, Cooler Master makes their RGB compatible with Asus and other motherboard RGB software if you have any.
If that doesn't do it, you will need to ask DS Support.
This page was generated in 2.441406E-02 seconds.
