Cooling Fan Question
Post Date: 2014-07-01
Tiwaz View Drop Down
  Quote Tiwaz Quote  Post ReplyReply bullet Topic: Cooling Fan Question
    Posted: 01 Jul 2014 at 1:10pm
So I'm customizing a Virtue to suit my needs and I'm wondering about CPU cooling. I'm getting an i5 4690K 3.50 GHz Devils Canyon with the standard Intel Turbo Boost 2.0 automatic overclocking so is the AIR: Stage 1: High-Performance Copper Heat Pipe Cooler going to be enough to keep my CPU cool? I'm thinking it should be enough because my CPU isn't always going to be running hot because it isn't manually overclocked. What do you guys think? Should I upgrade to a liquid cooling system or would it be overkill?
Nav View Drop Down
  Quote Nav Quote  Post ReplyReply bullet Posted: 01 Jul 2014 at 1:29pm
If you're going with the standard overclock, it will be more than enough.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 01 Jul 2014 at 1:29pm
An aftermarket air cooler, like the Hyper212, should work fine. It's considered stage 1 air cooling by DS standards. Not sure what the Performance Copper cooler actually is, but it should work, even on a light to moderate overclock along with the Hyper212, etc.
  Quote Tiwaz Quote  Post ReplyReply bullet Posted: 01 Jul 2014 at 1:33pm
Awesome. Thanks!
  Quote Tiwaz Quote  Post ReplyReply bullet Posted: 02 Jul 2014 at 9:22am
Ok Nav. What if I go with the i7 4790k with standard overclocking. Will the AIR: Stage 1: High-Performance Copper Heat Pipe Cooler still be more than enough?
Meller View Drop Down
  Quote Meller Quote  Post ReplyReply bullet Posted: 02 Jul 2014 at 10:15am
As long as it's the crappy stock cooler that comes in the CPU box, you're fine.
Oh god that was so hard for me to do... I'm such an avid overkill person.
Custom PC
Ryzen 9 5950X
Gigabyte X570 Aorus Xtreme
128GB DDR4 3600mhz
Samsung 980 Pro 512GB m.2
Samsung 960 PRO 2TB m.2 x2
  Quote Tiwaz Quote  Post ReplyReply bullet Posted: 02 Jul 2014 at 10:26am
Good to know :)
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 02 Jul 2014 at 10:26am
Meller, I've never seen this side of you.   Hahaha  Are you mellowing in your old, older, age?  LOL
  Quote Meller Quote  Post ReplyReply bullet Posted: 02 Jul 2014 at 10:34am
No... I just realized that not everyone has the money to spend on the higher end stuff... and I don't want to make anyone feel bad for not having a huge budget.
It's hard for me... so difficult. :/
Custom PC
Ryzen 9 5950X
128GB DDR4 3600mhz
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 02 Jul 2014 at 10:35am
This page was generated in 4.980469E-02 seconds.
