Cooling help - liquid vs. HAF
Post Date: 2009-10-02
brianm46804 View Drop Down
  Quote brianm46804 Quote  Post ReplyReply bullet Topic: Cooling help - liquid vs. HAF
    Posted: 02 Oct 2009 at 11:49am
I've never had a computer with liquid cooling and HAF nor do I know someone who does so I'm looking for comments and advise from those who have experience or knowledge.  I'm looking to buy 2 new computers by the end of the month and I went power but also as close to silence as I can get.
Which is better HAF or liquid cooling (or perhaps a combination)?
I've heard references to reseviours and types of liquid.  Does liquid cooling need to be refilled periodically?  If so, where can the liquid be obtained?
All thoughts are appreciated.
Synth3tikMessiah View Drop Down
  Quote Synth3tikMessiah Quote  Post ReplyReply bullet Posted: 03 Oct 2009 at 2:13pm
My last build was all liquid cooled, cpu and gpu etc.
I purchased all my things from danger den.
So here goes,
Liquid cooled will make any build more expensive. Unless you're planning on doing some major over clocking i'd steer clear of it 100% since its pretty much useless otherwise. Waste of money, can be a hassle to put together, test, and monitor. But it kept my system running EXTREMELY cool once all the kinks were out. (i had a plethora of issues with it in the beginning, leaks that weren't supposed to be there, faulty products(radiator), etc.)
If you ARE going to get the liquid cooling anyway. Since you've never done it before, i'd suggest having someone else set it up for you. It can get a little hairy/messy and you need to put some thinking into proper placement and direction of flow, etc.. Assuming all your parts are great and fully functional it should be ok, but there can be so much that can go wrong in a liquid cooling build i'd rather just pay for really good after-market air cooling.
If you're having DS set up the liquid cooling for you, then it wont be a problem, they'll test and retest everything and make sure its running flawlessly. If something does go wrong anyway, you have the tech support/warranty and everything so no worries there.
If you're doing it yourself, don't touch a THING until you watched a lot of instruction videos (danger den has a bunch). I'd even recommend writing out a schematic on paper of how your flow will go to make sure you don't make any mistakes in the process. Be careful! I accidentally fried one of my video cards even WITH the most expensive "non conductive" fluid on the market. Luckily managed to replace it for free. The more components that you have the higher the chances for little leaks. For ex. loose fittings, faulty connections, leaks in radiator, etc etc.
All that aside, liquid cooling is potentially quieter (fans are still involved in liquid cooling), looks awesome, and keeps your cards in freezing temps.
Sorry for the book i wrote, but after spending 4 or 5 years with liquid cooled system, i've been through it all. If you have any particular questions, feel free to ask i'll do my best to answer anything regarding order of flow, different components, opinions on products, etc.
Good luck!
  Quote Synth3tikMessiah Quote  Post ReplyReply bullet Posted: 03 Oct 2009 at 2:31pm
Yes, liquid does need to be refilled periodically. How often that is will depend on other factors. (its not very often regardless, unless you spring a leak or replace a part)
The fluid to use is FluidXP They're top notch in my experience. I recommend getting either the extreme line or nano line if you're doing HUGE overclocking. If you want to save some money use the ultra LT line.
http://fluidxp.com/index.php?page=shop.browse&category_id=6&option=com_virtuemart&Itemid=1
  Quote brianm46804 Quote  Post ReplyReply bullet Posted: 04 Oct 2009 at 12:04am
Thanks for the responses.  I will definitely buy (probably from DS) vs go the DIY route.  I am a little skeptical about the noise level for HAF cases since it still looks like they are using 4+ fans.  My current machine has the same number and sounds like an air conditioning unit sitting < 1 ft from me.  Since many of the DS models offer free CPU cooling I was wondering what is involved with that (you've sated my curiosity there, I think).
  Quote Synth3tikMessiah Quote  Post ReplyReply bullet Posted: 04 Oct 2009 at 2:20am
While an air cooled HAF may be loud because of the number of fans, if you use liquid cooling, you wouldn't need more than 2-3 fans tops.
I'd say a single fin for every component you're cooling is more than enough. So if you're only cooling your CPU and a single GPU. Thats two fans attached to either two separate radiators or attached to one big one (generally the size of the radiator will fit either 1 fan, 2 fans, or 3 fans).
If you're cooling a CPU and 2 GPU's you may need 3 fans, one for each, but i think you could easily get away with a single fan covering your CPU and a single fan covering the radiator for both GPU's...
These are the three sizes that i mentioned that fit either 1, 2, or 3 fans. Configure it any way you wish. But yea, it shouldn't be LOUD at all. And the HAF 932 is a greaaaat and roomy case that was designed very well for fitting different liquid cooling configurations!
venom View Drop Down
  Quote venom Quote  Post ReplyReply bullet Posted: 04 Oct 2009 at 2:25am
I am kind of surprised you are recommending them.  Their fluid is thick, grows weird stuff over time, clouds, stains tubing, and isn't very non-conductive.
Now that was what I experienced with their Extreme line, I haven't tried the Ultra LT or Nano.
And yeah, DangerDen does not make the greatest stuff, especially now.
Edited by venom - 04 Oct 2009 at 2:26am
  Quote Synth3tikMessiah Quote  Post ReplyReply bullet Posted: 04 Oct 2009 at 2:39am
Well the ultra LT line is supposedly much less viscous. And yea, most of the problems i had with the liquid cooling build were from faulty parts from DangerDen unfortunately. But i have never had any problems with the Fluid XP getting cloudy or growing stuff.
If you see bacterial growth and discoloration in your tubing that means that somewhere along the flow line it is not airtight (probably in the reservoir if you're using one). That plus warmed liquid will breed bacterial/organic growth in your tubing. (i had that happen to me using deionized water and dye actually). It turned my UV green into a not so UV pink, hahaha. And if your case lets some sunlight through to the tubing then the reaction happens even faster. But coolants like FluidXP (and others, koolance for example) have chemicals that prevent organic growth.
But you're free to use any coolant you wish! I've had great experience with Fluid XP... dropped GPU temps at idle from 40's to 20's and from 80/90 to high 40's under load!
  Quote venom Quote  Post ReplyReply bullet Posted: 04 Oct 2009 at 2:46am
Well I know it was air tight, so it was probably the warmth or the sunlight.
I'd recommend Feser One over most coolants.  You might want to try it out Synth as you might get even slightly lower temps.
  Quote Synth3tikMessiah Quote  Post ReplyReply bullet Posted: 04 Oct 2009 at 2:53am
I will definitely give it a try. Thanks a lot. But im trying to steer clear of the liquid cooling nightmare with this build unless i really need to cool the GPU's... I'll probably hop back onto liquid cooling later on down the road though! Feser One it will be!
  Quote venom Quote  Post ReplyReply bullet Posted: 04 Oct 2009 at 3:19am
If you are looking for better block makers I highly recommend EK for GPU and Motherboard blocks, Bitspower for Motherboard blocks, Swiftec (Apogee GTZ), HeatKiller, or EK for CPU blocks.
Fittings I would recommend Bitspower, either barb or compression.
Reservoir I would recommend Swiftec or Bitspower.
Radiators I would recommend Feser.
Pump I would recommend the Swiftec MCP355, although it sometimes has a short lifespan... Mine died in a year while others are still running after 2 years.
Tubing, any tubing works, but I use Tygon R3603.
Stick with well known and reviewed stuff and you can almost never go wrong.  Although there is still the chance you can receive a defective block from these companies, the chances are much lower than of those like DangerDen.
So far I have never had a leak in my system, nor any I have built.
Edited by venom - 04 Oct 2009 at 3:20am
  Quote Synth3tikMessiah Quote  Post ReplyReply bullet Posted: 04 Oct 2009 at 3:24am
Then next time you are building mine! I'll send you a check, lol.
  Quote venom Quote  Post ReplyReply bullet Posted: 04 Oct 2009 at 3:28am
Sounds good to me :)
  Quote Synth3tikMessiah Quote  Post ReplyReply bullet Posted: 04 Oct 2009 at 3:30am
Speaking of which, is there enough room to fit 2 gtx295's with gpu blocks given my mobo and case? Looks like a tight fit.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 05 Oct 2009 at 1:42am
DD gpu waterblocks are known for leaks. DD doesn't have its own rads.
yes you can fit 4 x 295 in your system if you wanted to as long as they are LCed.
Edited by DST4ME - 05 Oct 2009 at 11:50am
  Quote venom Quote  Post ReplyReply bullet Posted: 05 Oct 2009 at 4:42am
DangerDen rads are rebranded HW Labs rads I believe.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 05 Oct 2009 at 11:52am
No they are not, I know lot of people thinks this but I have asked this of DD before and they said that they are not affiliated, this was from a DD rep themselves.
HW is in Philippines and DD is in USA.
Edited by DST4ME - 05 Oct 2009 at 11:53am
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 05 Oct 2009 at 12:00pm
Smile ?? Danger Den sells HW labs rads, Thermochill Rads, and Feser Rads??  Don't know what the heck you are talking about?
  Quote venom Quote  Post ReplyReply bullet Posted: 06 Oct 2009 at 11:05pm
Ah well they looked identical so I assumed they were.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 7:55am
Lot of people think that, why do you think I asked myself long ago? I thought the same thing
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 9:06am
DD sells 3 brands of radiators, they do not make any of them.... Jeesh
 There is no such thing as a Danger Den radiator... If you buy a radiator from DD it will be a Feser, Thermochill, or HW labs..
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 11:04pm
Ya but there are sites that make it sound like hw is dd's rads.
This page was generated in 6.933594E-02 seconds.
