Cooling options
Post Date: 2011-04-03
hzatiger View Drop Down
  Quote hzatiger Quote  Post ReplyReply bullet Topic: Cooling options
    Posted: 03 Apr 2011 at 8:42am
I tried to do some searching on the forum but could not find the answer.
Is the TEC Sub-Zero LCS different from all the other Sub-Zero LCSs?
For instance could I get a special ops system with the TEC cooler or is the Sub-Zero LCS different?
thanks!
Edited by hzatiger - 03 Apr 2011 at 8:44am
maxyme View Drop Down
  Quote maxyme Quote  Post ReplyReply bullet Posted: 03 Apr 2011 at 9:02am
I'm guessing they are the same. The frost chill is differant though
Steam:pcmaster160
Divine View Drop Down
  Quote Divine Quote  Post ReplyReply bullet Posted: 03 Apr 2011 at 9:18am
No that are not the same, the TEC is DS specialized cooling for the x58 chips only, it uses multiple rads to achieve extremely low cooling temps, so low they had to design a foam around the cpu block to stop condensation. I believe its only available to the hailstorm case also, because it was designed around it and has the room to do so.
Stage 3 cooling is a 120mm rad, and stage 4 cooling uses a 240mm rad. I also believe the stage 3 doesn't use the same liquid reservoir as stage 4, with stage 4 I got a 240mm rad, swiftech cpu block and a xspc dual bay reservoir with pump.
Edited by Divine - 03 Apr 2011 at 9:21am
Haf-932
Asus Maximus Iv Extreme
2600k Overclocked ~ 4ghz
8gb Corsair Dominator DHX RAM
160gb Intel SSD
WD Black 500GB
850 Corsair PSU
Msi Twin Frozr Gtx 680
  Quote Alex Quote  Post ReplyReply bullet Posted: 03 Apr 2011 at 2:46pm
That's correct. If it does not say Liquid Chilled, and you did not pick it from the configuration that says TEC, then it is not our special cooling system that makes the CPU go to extremely cold temps (below 0'c).
bradsmokess View Drop Down
  Quote bradsmokess Quote  Post ReplyReply bullet Posted: 14 Apr 2011 at 5:19am
Each time a description of the change, there is always plenty to talk about around the world. They are not exempt. A statement usually is: "i have to change almost immediately versions, so do not expect me to date continue to attack  ...
william brad
dANGLICO View Drop Down
  Quote dANGLICO Quote  Post ReplyReply bullet Posted: 03 May 2011 at 2:32am
I recently ordered a hailstorm cased SB build and Divine was correct DS only offers Frost Chill on the X58 I7 9xx series chips and is unable to mod them to the SB processors. I was very dissapointed, but the Stage 6 LCS should be enough for me. It still confuses me why they offer Frost Chill on the drop down menus for SB builds, but their Sales department confirmed FC was not compatable with SB.
If they do end up offering the FC LCS for SB I would love to upgrade.
"In absence of orders go and find something to kill." Field Marshal Erwin Rommel.
Capt J
This page was generated in 4.589844E-02 seconds.
