Cooling problems
Post Date: 2011-06-18
WormholeX View Drop Down
  Quote WormholeX Quote  Post ReplyReply bullet Topic: Cooling problems
    Posted: 18 Jun 2011 at 2:58am
Hello,
I was having some problems with CPU cooling. My CPU quickly reaches 100C (~2 min).
I'm using the stage 4 cooling system (CPU waterblock, reservoir, radiator, pump). There is plenty of water in the reservoir, but the tube from the cpu to the reservoir is hot while from the cpu to radiator is cold. I suspect this is due to a broken pump, although I cannot actually see if the water is flowing through the dark blue tube. Any other way I could diagnose this?
Thanks,
WormholeX
Edited by WormholeX - 18 Jun 2011 at 3:02am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Jun 2011 at 5:44am
Put your hand on the pump, you should feel a slight vibration, the fact that your temps are too high, and from your tube explanation, sounds like your pump is not working.
