Cooling question/problem
Post Date: 2010-05-14
Niloh View Drop Down
  Quote Niloh Quote  Post ReplyReply bullet Topic: Cooling question/problem
    Posted: 14 May 2010 at 12:47pm
I'm using dual-loop liquid cooling to cool both my processor and my video card (ATI 5970) and am currently working with DS to replace my coolant reservior since the one I have is cracked and the coolant level is only about half full.  I started having a problems with my video card overheating and it shutting the system down, at first this only happened occasionally but now it is happening every time I boot the computer.  Previously it has been working fine and the warmest it ever got according to my catalyst control panel was 35C but suddenly it's idling at 55-65C and I've seen it as high as 77C before it turned itself off.  I've cleaned the system and used compressed air to make sure all fans were functional and unclogged and that nothing had come unconnected.  I can feel vibration of the water passing through the tubes however the water is always warm now.
My question is, could the coolant level in the reservior cause this problem all by itself?  Would having a full reservior make that large of a difference in the heat level?
I'm hoping that replacing the reservior with a new uncracked and full one will fix the problem but in the meantime I'm seeking input on what the problem could be and possible solutions.
Edit: Just tried to launch a game, temp of card immediately jumped to almost 100C
Edited by Niloh - 14 May 2010 at 2:00pm
  Quote Niloh Quote  Post ReplyReply bullet Posted: 14 May 2010 at 2:44pm
I just took another closer look at the reservior, it appears to be a box split in half down the middle.  On each side there is a hose connected to the top and one connected to the bottom.  On each side at the bottom of the reservior there is what appears to be a blue wheel, which I'm assuming has something to do with how it feeds water into the lower tubes.  On one side the wheel is spinning, on the other side it appears to be stuck, it is trying to spin but it can't (it resembles a broken clock trying to tick in that it starts to go forward then it goes back). After doing some web searching on the Sub-Zero LCS which is what I have, I'm not seeing a wheel in the reservior so I'm thinking it may be part of the pump but I'm not certain.
Edited by Niloh - 14 May 2010 at 2:54pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 14 May 2010 at 7:33pm
the blue wheel is the impeller, and yes it should be spinning fast,
  Quote Niloh Quote  Post ReplyReply bullet Posted: 15 May 2010 at 12:12pm
ok, you can consider this issue closed, I spoke to DS tech and they are sending me a new reservior to replace the cracked one and one new pump to replace the one with the broken impeller
  Quote Alex Quote  Post ReplyReply bullet Posted: 15 May 2010 at 3:03pm
If you need help installing it, we're a call away.
Have a great weekend,
Alex
