Cooling questionPost Date: 2009-01-25 |
| Author | |
Moeror
Joined: 27 Sep 2008 Online Status: Offline Posts: 44 |
Topic: Cooling questionPosted: 25 Jan 2009 at 2:59pm |
With specs like this, are fans fine or should i get cooling? ALso how does this vid card compare to 2x Geforce GTX 260's 896mb? Would the dual cards really increase performance, or is the card I already have a monster and it wont make much difference?
Chassis Model: Cooler Master HAF 932 Exterior Finish: - Standard Factory Finish Interior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 940 2.93GHz (Quad Core) Motherboard: ASUS P6T Deluxe (Intel X58 Chipset) (Supports Dual SLI or CrossFire) System Memory: 3GB DDR3 1333MHz Corsair Dominator DHX (High-Performance) Power Supply: 750W Corsair TX (Dual SLI Compatible) (Silent Edition) Card Reader: Internal Digital Media Card Reader (Black) Hard Drive Set 1: Operating System: 1TB Western Digital (7200 RPM) (16MB Cache) (SATA) (Extreme Speed) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: - No Thanks Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD±R/RW/CD-R/RW (DVD Writer 20x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 1x NVIDIA GeForce GTX 280 1GB (Includes PhysX Technology) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: AIR: Stage 2: Cooler Master V8 (Compatible With i7 Processors) Liquid Color:- Not Applicable, I do not have a H20: Stage 3 Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (Blue) Enhancements: - No Thanks Chassis Mods: - No Thanks Boost Processor: - No Thanks, Please do not overclock my processor Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Tweak Windows: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows Vista Home Premium (64-Bit Edition) (For Enthusiasts) Restore Kit: Digital Storm Specialized Recovery System (DVD Image Based) Virus Protection: - No Thanks Office: - No Thanks Benchmarking: - No Thanks Install/Test Game: - No Thanks LCD Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: - No Thanks Priority Build: - No Thanks Warranty: 3 Year Platinum Care Extended Parts & Labor Warranty Edited by Moeror - 25 Jan 2009 at 3:05pm |
widdlecat
Joined: 11 Mar 2008 Online Status: Offline Posts: 840 |
Posted: 25 Jan 2009 at 3:18pm |
The cooling is great the way you've configured it. If you wanna do some aggressive overclocking on your own later, liquid cooling can give you best results, but the V-8 is an excellent performing air cooler that many are using while overclocking.
Sodius
Joined: 18 Jan 2009 Online Status: Offline Posts: 613 |
Posted: 25 Jan 2009 at 3:29pm |
If you went with the 295 card it is slightly better than 2 260's.
Posted: 25 Jan 2009 at 8:14pm |
give me your ticket number, budget and what resolution you gonna be gaming at.
your resolution will decide what card/s you should go with and a 260+ sli will kill a single 280. but what you need depends on your resolution |
