Cooling questions
Post Date: 2008-09-27
Moeror View Drop Down
  Quote Moeror Quote  Post ReplyReply bullet Topic: Cooling questions
    Posted: 27 Sep 2008 at 8:44pm
For a rig like this which would be better, the Stage 2 cooling, or the Stage 3 with all the air fans. Im gonna be gaming the hell out of this thing, so should i go ahead and get the maximum fans, or does stage 2 do a good job of keeping things under control?
System Memory: 4GB DDR3 1333MHz Corsair
Hard Drive 1: 750GB Western Digital (7200 RPM) (16MB Cache) (SATA) (Extreme Speed)
Hard Drive 2: - No Thanks
Raid Option: - No Thanks
Hard Drive 3: - No Thanks
Video Card: NVIDIA GeForce GTX 280 1GB (Includes PhysX Technology)
TV Tuner: - No Thanks
Modifications: - No Thanks
Windows OS: Microsoft Windows Vista Home Premium
Protection: - No Thanks
LCD Display: - No Thanks
Keyboard: Microsoft Multimedia Desktop 3.0 (Multimedia Keyboard + Optical Wheel Mouse)
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 Sep 2008 at 8:55pm
ticket number please?
  Quote Moeror Quote  Post ReplyReply bullet Posted: 27 Sep 2008 at 8:58pm
I dont have one. Im just curious about which cooling option i should choose. Did i post in the wrong forum?
  Quote Moeror Quote  Post ReplyReply bullet Posted: 27 Sep 2008 at 9:00pm
It's 187952
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 Sep 2008 at 9:02pm
well that all depends, with the case you have chosen, its basically at stage 3 already in fans so you should stage 2.
if you want to OC your CPU and ram , which you should then go with CPU liquid cooling. But if you change that configuration then what cooling you should use changes.
but there is a better way to configure the system you have listed.
at the top of the page where you copied the text you have listed, there is a ticket number listed, if you give me that I can offer you some better suggestions.
hope that helps.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 Sep 2008 at 9:05pm
got your ticket number thank you.
what is the resolution you are going to be playing games at?
  Quote Moeror Quote  Post ReplyReply bullet Posted: 27 Sep 2008 at 9:06pm
for now 1280x1024. Prob not gonna chance anytime soon unless i see some amazing deal or something.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 Sep 2008 at 9:09pm
ok thank you, this is a better setup.
HDD1 is for OS, apps and games only
HDD2 is for media/personal files.
each drive is independet, so if one breaks you don't lose data on the other drive.
here you go Ticket# 187962 --- Price: $2758 (To see this build click here)
questions? ask away
if you got the budget I highly recommend you OC this system, with liquid cooling you could be around 3.4GHz to 3.8GHz
Edited by DST4ME - 27 Sep 2008 at 9:10pm
widdlecat View Drop Down
  Quote widdlecat Quote  Post ReplyReply bullet Posted: 28 Sep 2008 at 12:44am
I agree with DST on that config... liquid cooling and OC would rock if your gonna be "gaming the hell out of this thing".
If you use a gaming headset, I'd recommend at least considering the Razer Baraccuda sound card.
