Cooling related questions
Post Date: 2013-06-23
overanalytical View Drop Down
  Quote overanalytical Quote  Post ReplyReply bullet Topic: Cooling related questions
    Posted: 23 Jun 2013 at 8:43pm
Still pondering my build (ticket 840687, details in my earlier thread), now I have a questions about mechanics of cooling.
Chassis: Corsair 550D
So I initially believed the airflow was as described by Corsair for the case and similar for other cases where you have 3 fans... 2 in front as intake, and 1 in rear as exhaust. I figured that the radiator would just attach to the existing fan of the case and it would pull the hot air from the radiator outward. I then realized these coolers come with fans. I then read the Corsair hydro cooler instructions for their various models and they say it is best that this cooler fan(s) be configured as intake. I then wondered, well where does the hot air go? I asked some techs/salespeople at Microcenter and they said it goes out the top, and yes nowadays this is the way you do it. So I need at least one fan at top.
So:
1) What will DS do to my system which as configured has 3 fans that come with the chassis? Will they take the 3rd fan and put it on top, and make the rear (as part of the CPU cooler) be intake? The 550d comes with a lid on top so I guess they remove it?
2) The Digital Storm Vortex I assume comes with 2 fans like the H80. Do you need an extra fan header on the motherboard for the second fan, so you need 2x 4-pins, plus 1x 3-pin for the pump? I'm trying to add up how many fans the mobo supports and what I'll be running in the end.
3) If I get the asus z87 sabertooth it's got the thermal armor stuff including two more mini fans. Do they use any of the fan connectors? I almost wonder if this plastic shield actually keeps heat in and/or if it's a gimmick. I am almost thinking I prefer the Asus Z87-Pro instead. It's cheaper and has more other types of bells and whistles aside from this thermal armor stuff. It also has the software for automatic overclocking (I watched an Asus video) which sabertooth doesn't seem to have?
4) I noticed the Asus Z87-Pro/Deluxe/C and maybe others do not have 3-pin fan connectors. Can you plug a pump with a 3-pin connector into a 4-pin mobo header?
Thanks
Edited by overanalytical - 23 Jun 2013 at 8:44pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 24 Jun 2013 at 2:51am
The 550d will have the ftont fans blowing in and the rear fan blowing out. With Vortex 120 both fans mount on either side of rad in push/pull meaniing the one blows in and the other blows out so both blow in same direction.    The Vortex 120 mounts against the rear wall replacing stock rear fan and blow out. DS might use a 'Y' connector so both use same fan header but not sure.      Both the top and side covers of 550d stay on but you can take them off.
The Sabertooth heat shield has mostly good reviews. It also carries a 5 year warra ty vs 3 years for most others because of its better components. The Pro mobo is a real nice board. Your choice.
The Sabertooth shirld is removable and the small fans do use a fan header.
3 pin fans can plug into 4 pin fan headers. They're keyed so they can't be plugged in the wrong way. Fans can also connect to the 4 pin peripheral cables from power supply with a 3 pin to 4 pin pass through adapter.   Not all fans need the mobo.
Edited by bprat22 - 24 Jun 2013 at 2:53am
