Cooling System Fans
Post Date: 2019-03-25
Ananas View Drop Down
  Quote Ananas Quote  Post ReplyReply bullet Topic: Cooling System Fans
    Posted: 25 Mar 2019 at 3:17pm
Hello all,
I have been poking around my lumos and I noticed that the fans mounted to the 240mm Digital Storm Vortex cooling system were RGB. I have been thinking about replacing my stock fans with corsair rbg fans, and I wonder if I can use the two on the cooling unit as a test to see how it would look before I commit to buying 6 expensive fans.
Any hardware issues with this idea?
HockeyBuck View Drop Down
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 25 Mar 2019 at 9:59pm
Not sure what is the RGB controller for those two fans might be.
If you buy for example a Corsair LL or ML Series 120mm RGB fan 3 pack, that comes with the Corsair Lighting Node Pro unit that the fans plug into, and the RGB colors are then controlled by Corsair iCue software.
  Quote Ananas Quote  Post ReplyReply bullet Posted: 07 Apr 2019 at 9:07am
Update: I contacted tech support and it looks like you can remove the fans without voiding the warranty
