Cooling System
Post Date: 2010-07-07
flllyi View Drop Down
  Quote flllyi Quote  Post ReplyReply bullet Topic: Cooling System
    Posted: 07 Jul 2010 at 4:46pm
Hey, I have a quick question. I was contacted by DS saying that the Noctua Dual 120mm is on back order... They said I could wait for them or pick a different cooling system. Can anyone take a look at my build and give me a suggestion on what to do. Thanks alot!
Hard Drive Set 1: Operating System: 1x (1TB Seagate/Hitachi (7200 RPM) (32MB Cache) (SATA) (Extreme Speed)
Video Card(s): 1x NVIDIA GeForce GTX 480 1.5GB (Includes PhysX Technology)
CPU Boost: FREE: Stage 1: Overclock the processor between 3.3GHz to 3.9GHz (Cooling Upgrade Recommended)
  Quote flllyi Quote  Post ReplyReply bullet Posted: 07 Jul 2010 at 4:49pm
Should I wait for Noctua or go for Coolermaster V8?
Dragoonseal View Drop Down
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 07 Jul 2010 at 5:00pm
Wait for the Noctua.
Lilim
Intel Core i7 920 @4.2GHz
  Quote flllyi Quote  Post ReplyReply bullet Posted: 07 Jul 2010 at 5:07pm
okay then, thanks alot
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 07 Jul 2010 at 7:20pm
what about the Noctua 14?
  Quote Alex Quote  Post ReplyReply bullet Posted: 07 Jul 2010 at 8:13pm
I believe that is in stock.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 07 Jul 2010 at 10:52pm
or you could probably order one online and send it to dso if you didnt want to wait
This page was generated in 4.589844E-02 seconds.
