Cooling
Post Date: 2010-08-29
YoursTruly View Drop Down
  Quote YoursTruly Quote  Post ReplyReply bullet Topic: Cooling
    Posted: 29 Aug 2010 at 1:51pm
AIR: Stage 1: Noctua Dual 120mm Fans High Performance Cooler (Compatible With ONLY i7 Processors) vs  H20: Stage 2: Asetek Liquid CPU Cooler HOT SELLER (120mm Radiator) (Great Value), I was wondering which one has better performance? Ninja
Dragoonseal View Drop Down
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 29 Aug 2010 at 1:53pm
The Asetek Liquid CPU cooler is just LC for the sake of saying it is LC. It isn't exactly known for its construction quality or reliability either. Its cooling pales terribly compared to real LCing, even good air coolers such as either of the Noctua models offered by DS will outperform it, especially the larger Noctua NH-D14. Select one of the Noctua coolers instead.
Lilim
Intel Core i7 920 @4.2GHz
al3xLJ View Drop Down
  Quote al3xLJ Quote  Post ReplyReply bullet Posted: 29 Aug 2010 at 1:56pm
Noctua is the way to go there my man, Asetek is not real liquid cooling, its just some water running around your pc in tubes, whereas Noctua is probably the best air cooling out there.
  Quote YoursTruly Quote  Post ReplyReply bullet Posted: 29 Aug 2010 at 1:56pm
Thanks for the quick response ^^. was really curious about this one
  Quote al3xLJ Quote  Post ReplyReply bullet Posted: 29 Aug 2010 at 2:04pm
NP Wink
