Copper Tubing Water cooling Option
Post Date: 2015-09-09
db188 View Drop Down
  Quote db188 Quote  Post ReplyReply bullet Topic: Copper Tubing Water cooling Option
    Posted: 09 Sep 2015 at 4:12pm
i was messing around with the configurator today and noticed that the copper/chrome tubing under extreme cooling had been removed.  has DS discontinued this as an alternative to Hardline acrylic and soft tubing options? please say it isn't so...Sad
Edited by db188 - 09 Sep 2015 at 4:13pm
Steven View Drop Down
  Quote Steven Quote  Post ReplyReply bullet Posted: 09 Sep 2015 at 4:18pm
We were seeing a lot of recurring issues with the copper builds and we've decided to remove them for now while we do some testing.
I also really love the copper tubing so I'm hoping we can get everything sorted ASAP!
Edited by Steven - 09 Sep 2015 at 4:19pm
  Quote db188 Quote  Post ReplyReply bullet Posted: 09 Sep 2015 at 7:18pm
can you elaborate?  was it a corrosion problem?  leaks?  some kind of flow restriction?  i wouldn't think it's corrosion as long as you don't have two different kinds of metal inside the loop.  just curious.
  Quote Alex Quote  Post ReplyReply bullet Posted: 10 Sep 2015 at 11:08am
The copper piping had no issue with it. It's just that we don't have them ready for the AVENTUM 3 launch. That will happen later down the road.
