Corsair 230T case help(Vanquish II)
Post Date: 2014-11-02
Rockcem View Drop Down
  Quote Rockcem Quote  Post ReplyReply bullet Topic: Corsair 230T case help(Vanquish II)
    Posted: 02 Nov 2014 at 7:48pm
Okay so i'm trying to take off the front panel of the case so i can clean it (Its kinda dusty). What i have to do is take off the little latch thingys. There is 6, 3 on each side. the bottom 4 are easy but the top 2 will not budge. I don't know if i'm doing something wrong or if have to unscrew something. But any help will be greatly appreciated.
*The Beast Has been Acquired*
  Quote Snaike Quote  Post ReplyReply bullet Posted: 03 Nov 2014 at 12:01am
Hi Rockcem ... yea, it can be a bit disconcerting first, but all 6 latches are the same. You have to get your fingers in there and push them back. The first time I did it, I thought I broke something.
The top two latches being in a 'blind' area, along with the fact that the power buttons and USB ports are there, make it necessary to try to get those two undone first. THEN go to the bottom ones. I found that if I undo the bottom four latches, it puts an additional twisting strain on the top two.
I hope that helps. Oh, btw, if you're cleaning filters, don't forget the slide out filter on the bottom for the PSU. Somewhere on these forums I posted some pics... I'm going to see if I can find them and drop a link into this post.
Good luck!!!
  Quote Snaike Quote  Post ReplyReply bullet Posted: 03 Nov 2014 at 12:26am
Here it is...
http://www.digitalstormonline.com/forums/removing-dust-from-the-mesh-filter-on-vanquish-tidf22849/
As you can see, the latches on the top are exactly the same as the ones below. Best bet is get them first... work top to bottom.
I've had my cover off at least a dozen times and those two latches still give me a bit of a bother. (Could be my catchers mitt sized hands, though.)
Hope this helps.
Meller View Drop Down
  Quote Meller Quote  Post ReplyReply bullet Posted: 04 Nov 2014 at 3:22am
Custom PC
Ryzen 9 5950X
Gigabyte X570 Aorus Xtreme
128GB DDR4 3600mhz
Samsung 980 Pro 512GB m.2
Samsung 960 PRO 2TB m.2 x2
