Corsair CMXAF2 fan white mod.
Post Date: 2010-04-17
Ambidex View Drop Down
  Quote Ambidex Quote  Post ReplyReply bullet Topic: Corsair CMXAF2 fan white mod.
    Posted: 17 Apr 2010 at 7:55am
Hello everyone,
As you can see in the Da Vinci setups, they have colored the ram fan white.
I really want this too.
But I do not want to mod it myself.
Is it possible to order the fan modified white from digital storm?
Additional Question
Is it possible to order a complete water cooling setup? So all I need is to install it myself?
Chris
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Apr 2010 at 6:25pm
you can ask DS to paint your fan's blades whatever color you like.
DS does not sell a LC kit, its parts from different companies that one puts together. in short if you know what you are doing, then you order the parts yourself and install them yourself.
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 17 Apr 2010 at 6:29pm
I guess you can probably order a LC loop from DS pre-assembled, however, the only thing is how long the tubing will be. It has to be custom tailored to how your case parts are arranged, so DS might or might not be able to make one for you. If you know what you're doing though, by all means, build one yourself. DS just simplifies the process while you're ordering a rig, if you go around looking for parts on your own, then you'll have a lot more flexibility.
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Apr 2010 at 6:31pm
it is going to cost so much to do it that way tho, and still you gonna need to take it apart to install some of it.
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 18 Apr 2010 at 12:13pm
Do any of u guys know what kind of paint I can use to mod my cmxaf2 ram fan?
Cause I live in Hungary, Im a student, and I dont speak very well hungarian, so I might need to order it from ebay or something.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Apr 2010 at 3:38pm
Contact DS and see what they use. form what I have seen they do a great job, my ram fan's blades were painted red.
