Corsair liquid cooling ..
Post Date: 2009-12-02
philiporphillip View Drop Down
  Quote philiporphillip Quote  Post ReplyReply bullet Topic: Corsair liquid cooling ..
    Posted: 02 Dec 2009 at 11:51pm
is the Corsair Hydro H50 CPU Liquid Cooler any good? it looks very similar to DS's Asetek LCLC Processor Liquid Cooling System.
it never has to be filled with a coolant since everything is sealed .. it has 50000 hour-life, BUT what happens if it's close to replacing it with a new one? HOW will i know when it's almost dead when there's no warning beep .. i DON'T want to play Crysis in my oc'd pc and all of a sudden my cpu gets melted.
should i just replace it every 6 months?
thanks !!
Digital Storm
haf 922
i7-920 oc'd @ 3.6 ghz (1.28v)
evga x58 le edition sli
cooler master v8
6 gb ddr3 1600 mhz mushkin
evga nvidia geforce gtx 295 co-op edition
1000w corsair hx
MyNameisBrian View Drop Down
  Quote MyNameisBrian Quote  Post ReplyReply bullet Posted: 03 Dec 2009 at 12:04am
First off, 50000 hours is more than 5 years, close to 6 I believe.
Second, from what I've heard, some air coolers like the Noctua are actually better than the Asetek and those like it.
  Quote philiporphillip Quote  Post ReplyReply bullet Posted: 03 Dec 2009 at 1:06am
yes, i'm aware of the years, but liquid cooling is more vulnerable than air cooling. hence, the replacement question.
i'm beginning to think air cooling is becoming too large in size.
Digital Storm
haf 922
cooler master v8
1000w corsair hx
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 03 Dec 2009 at 10:43am
they have not been around enough to see if they do actually last 50000 hours.
corsair's is a bit better but I would go Noctua NH-U12P or frostchill/zubzero, asetek is a waste of your time.
Kyu View Drop Down
  Quote Kyu Quote  Post ReplyReply bullet Posted: 03 Dec 2009 at 12:13pm
lol, and they're getting bigger once you stick more fans on.
I don't really care on the reviews of asetek, saw a few of them being checked to be installed, while i was installing other things in pc's
and I honestly thought they were some non name brands, look so cheap.
Noctua is good, but TRUE 120 EE is good as well.
I only liked Noctua cause it comes with one of the best cpu heatsink fans, Great static preasure at low dBA
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 03 Dec 2009 at 12:40pm
the Noctua NH-U14P is even better
AndydViking View Drop Down
  Quote AndydViking Quote  Post ReplyReply bullet Posted: 03 Dec 2009 at 4:23pm
I have an asetek and my temps are fine.  These things aren't having some sort of high failure rate are they?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 03 Dec 2009 at 4:57pm
should be ok but they have not been around long enough for us to say.
