Corsair Obsidian Help (not ds related)
Post Date: 2010-02-01
sirsiddius View Drop Down
  Quote sirsiddius Quote  Post ReplyReply bullet Topic: Corsair Obsidian Help (not ds related)
    Posted: 01 Feb 2010 at 7:17pm
I'm planning on using the Corsair Obsidian when I build my wc'ed rig, and I want to know if I can put a pump in the space reserved for the hot swap 3.5 inch bays.
For example in the Haf you can remove those plastic hd holders and install a pump directly into the the space reserved for the hd's. As shown here:
www.overclock.net/attachments/computer-cases/95317d1232888551-cooler-master-haf-932-922-club-ca390197.jpg
I've been looking at pictures of the Corsair 800 for hours and I can't figure out if there are spacers between the 3.5 bays which would make installing a pump impossible, or if there were spacers, weather they are removable. I know many DS forum posters have this case, and I know that DS's build team probably know these cases like the back of their hands.
Can someone tell me weather it's possible to install a pump in the corsair in a manner similar to the haf show in the link?
Thanks.
Edited by sirsiddius - 01 Feb 2010 at 7:18pm
gytarplayindude View Drop Down
DS Quality Assurance/Technical Support
  Quote gytarplayindude Quote  Post ReplyReply bullet Posted: 01 Feb 2010 at 8:28pm
Without drilling or cutting it is not possible.  There is not enough room for hoses to runn from any direction.  However, you could use a drillbit made for cutting holes in metal and make it work.  It would actually look very nice if done correctly.
Chris Thompson
Technical Support/Quality Control
CPU: E8400
Memory: 4GB Corsair 667Mhz
Graphics: EVGA 8800GT 512
OS: Windows 7 Ultimate
Steam: gytarplayindude
