CorsairLINK2 and Corsair AX1200i Digital ATX PSU
Post Date: 2013-05-23
Crono View Drop Down
  Quote Crono Quote  Post ReplyReply bullet Topic: CorsairLINK2 and Corsair AX1200i Digital ATX PSU
    Posted: 23 May 2013 at 11:50am
CorsairLINK 2.2 was installed on my system, and I found the update (2.3) for the software which I installed from their website.
http://www.corsair.com/us/power-supply-units/ax-series-power-supply-units/ax1200i-digital-atx-power-supply-1200-watt-80-plus-platinum-certified-fully-modular-psu.html
Prior to the update, CorsairLINK 2.2 was able to see the PSU, but not the GPUs in the monitor. Now with the latest update, I'm not seeing the the PSU, but I'm now able to see GPUs.
Not a deal breaker here, but anyone have suggestions as to why this is?
Edited by Crono - 23 May 2013 at 11:55am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 23 May 2013 at 12:00pm
Some parts , and that psu might be one of them, need to be hooked to the mobo's usb port by an included cable to be monitored.
See if there's a cable included that you can use.
  Quote Crono Quote  Post ReplyReply bullet Posted: 23 May 2013 at 12:04pm
Ahhh, there was a cable hanging out in the rear of the case, I'll check it out when I get home. I didn't think that had any effect seeing as the previous version of the software didn't have any issues seeing the PSU.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 23 May 2013 at 12:07pm
I'm thinking every software update changes things around a bit.  They like to keep you guessing. LOL
Not sure the cable you want would be hanging out of the rear of the case.  I would think its all internal from where the harness plugs in to the mobo.  But, not sure.  Let us know what you find.
Edit.. on second thought maybe the cable is meant to plug into a rear i/o usb port , same area as mouse, keyboard, etc.
Edited by bprat22 - 23 May 2013 at 12:14pm
tju76 View Drop Down
  Quote tju76 Quote  Post ReplyReply bullet Posted: 23 May 2013 at 10:03pm
I would imagine the cable Hanging out the back is for the rampage if oc key
