Could use some help
Post Date: 2009-07-18
Izzard View Drop Down
  Quote Izzard Quote  Post ReplyReply bullet Topic: Could use some help
    Posted: 18 Jul 2009 at 2:18pm
Hey everyone,
This is my first attempt at build specs, all the other machines I’ve ever owned were store bought and required very little thought.  As much as I love video games I don’t know much about the machines that make them run.  This is why I would appreciate any and all help I can get from this community.
First off I have a budget of roughly $4,000 and with that I need a computer and monitor (24”).  The monitor I will buy separate from this build, but it still needs to be figured in.  No, I do not have a monitor in mind.  However, my company gets a discount from Dell, so I will probably be looking at taking that route.
I’m a big fan of FPS’s which I intend to play more of when I get a machine that can handle them, I’m also into MMO’s.
I have already looked over some of the other threads before making these selections, so I hope it’s not too much of a cluster…
One of my concerns is with the HD, is it worth getting the 300GB VelociRaptor over a slower HD?  A friend (not an expert) said I should get the 150GB VelociRaptor x2 in raid 0, what are your thoughts on this?
Also the video cards I have selected are they enough to run the more current games at good or great settings?  If not and I get a third video card is air cooling going to be enough?
And it doesn’t have to be only upgrades, trim some fat if need be.  My wallet won’t mind!  Ouch
Thanks!
Direct Load URL: http://www.digitalstormonline.com/comploadsaved.asp?id=309595
System Memory: 6GB DDR3 1333MHz Digital Storm Certified by mushkin enhanced (Highly Recommended) (Hand Tested)
Card Reader: - No Thanks
Hard Drive Set 1: Operating System: 1x (300GB Western Digital VelociRaptor (10K RPM) (16MB Cache) (Extreme Speed)
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 275 896MB (Includes PhysX Technology)
Enhancements: LCD Temperature Display & Fan Controller (Requires Chassis Airflow Upgrade)
LCD Display: - No Thanks
Jennings386 View Drop Down
  Quote Jennings386 Quote  Post ReplyReply bullet Posted: 18 Jul 2009 at 5:03pm
It fits in your budget so I would seriously consider upgrading to the Stage 3 Frostbite.  I was a bit leery of getting LC (because of shipping damage), but I am very glad I went that route.  If you stick with air cooling, the Noctura is the way to go, along with the upgraded fans.
I would also think about upgrading to the 4 or 5 yr warrenty if you plan on keeping the build around for a while.  The extra peace of mind never hurts.
I would also think that the single Raptor is better than the raid 0 set up.  Raid 0 is better performance, but is probably not worth the risk.  I'm sure that some others will tell you to get a HDD to get you by for now and to add a SSD later when the prices have come down.
e.fruman View Drop Down
  Quote e.fruman Quote  Post ReplyReply bullet Posted: 18 Jul 2009 at 6:07pm
DELL ULTRASHARP 2408WFP for the monitor
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Jul 2009 at 7:07pm
If your budget is $4000 then this is what you want, the ocz vertex will beat veloci in raid:
Here you go Ticket# 309738 --- Price: $3667 (To see this build click here) Price after current promotion $3417
Hard Drive Set 1: Operating System: 1x (250GB Solid State (By: OCZ) Vertex Series (Model: OCZSSD2-1VTX250G)
that leaves you with $600 for a monitor.
  Quote Izzard Quote  Post ReplyReply bullet Posted: 18 Jul 2009 at 9:12pm
Thank you guys for your help so far, these are all good suggestions. Ermm
DST4ME even though the 250 SSD is with in my range, would one with a smaller amount of storage like the 120 be worth the cut in price?  or is it if your going SSD go BIG or go home.   Also if one did get the 120 SSD could one get a second HD to run everything but games?  This is where i don't have a clue on how things work...
Big%20smile
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Jul 2009 at 9:26pm
ok HDD1 = fast drive for os/apps/games
HDD2 = slow dirve 7200rpm for file storage.
I only gave you the 250GB cause games take space, however if you think 120GB is enough for you go with 120GB
notice I chose vertex for you, all ssds are not the same, so go with vertex, the 250GB and 120GB have the same speeds
  Quote Izzard Quote  Post ReplyReply bullet Posted: 18 Jul 2009 at 10:04pm
Thank you sir!
With that bit of information I think I'm good to go, just need to pull the trigger..
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Jul 2009 at 10:04pm
My pleasure
call Sarah at 1-866-817-8676 Extension: 115 and she will set you up
