CPU cooling
Post Date: 2011-01-06
DSnoob View Drop Down
  Quote DSnoob Quote  Post ReplyReply bullet Topic: CPU cooling
    Posted: 06 Jan 2011 at 3:01am
what is the main difference between Noctua D14 vs the U12? How much more over clocking can get with U12 for a 950 chip?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 06 Jan 2011 at 3:06am
The d14 has 2 x 140mm fans 1 x 140mm fans and 1 x 120mm fan, the u12 has 2 x 120mm fans.
here at ds with either and stage 1, you will endup with the same oc speed on the same chip, which is around 3.7 to 3.9
Edited by DST4ME - 06 Jan 2011 at 5:16pm
Dragoonseal View Drop Down
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 06 Jan 2011 at 4:43pm
The NH-D14 has one 140mm fan and one 120mm fan, the option to add a third fan (but you have to buy a third yourself), and has much more heatsink surface area.
The NH-U12P has two 120mm fans.
Lilim
Intel Core i7 920 @4.2GHz
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 06 Jan 2011 at 5:16pm
I stand corrected, its the c14 that has 2 x 140mm fans, the D14 as mentioned by dragon has 1 x 140mm and 1 x 120mm fans.
