CPU fan control
Post Date: 2011-08-20
Bensonc120 View Drop Down
  Quote Bensonc120 Quote  Post ReplyReply bullet Topic: CPU fan control
    Posted: 20 Aug 2011 at 10:34pm
So I am using MSI Afterburner to set the gpu fan profile.  Is there a similar program that is recommended for the cpu fan settings?  I've read a couple forums and they seem to recommend Speedfan.  Do you guys recommend this program?
Thanks for your help.
PS I have the A70 cooler.
Thermaltake Core
Intel Core i5-10400
MSI Z490
Vengeance 32GB DDR4 3200mhz
Samsung M.2 SSD EVO 970 1TB
Asus ROG Strix 1080 Ti
Asus PG278QR Monitor
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Aug 2011 at 2:58pm
Speedfan would do it but its temps are not accurate, you can also change that in the bios and asus probably has some utility to let you do that thru windows also.
unless you have issues with your cpu temps, I would leave that one alone.
