CPU Fan Question
Post Date: 2009-05-27
MyNameisBrian View Drop Down
  Quote MyNameisBrian Quote  Post ReplyReply bullet Topic: CPU Fan Question
    Posted: 27 May 2009 at 9:22pm
I'm doing some upgrades on my mom's PC, which I built a while back for her.
I currently have the stock CPU fan on it, but I want to upgrade that and do a small OC for her. Do you guys have any suggestions . . . CPU is an AMD 64 X2 and mobo is a MSI 780 I think.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 May 2009 at 9:51pm
ARCTIC COOLING Freezer
seems to be a good one.
SunfighterLC View Drop Down
  Quote SunfighterLC Quote  Post ReplyReply bullet Posted: 28 May 2009 at 12:20am
Just make sure to check out the measurements and make sure you have the clearence
E8500@ 4.03Ghz
XFX 790i Ultra
1000W Corsair HX
2 280 GTX EVGA FTW
4GB OCZ Reaper 1800Mhz
250-80-300GB VR HD
Logitech Z-2300 2.1 Speakers
Asus Xonar 7.1
Clinton View Drop Down
  Quote Clinton Quote  Post ReplyReply bullet Posted: 28 May 2009 at 12:35am
Don't know if the Arctic 7 will fit, but it's an amazing heatsink.
  Quote MyNameisBrian Quote  Post ReplyReply bullet Posted: 28 May 2009 at 2:14am
Thanks! I'll go with Arctic 7 whenever its back in stock . . .
I'm swapping cases too so there will be plenty of space.
I also have some RAM from my old build that I was thinking about adding. They are at the same speed (800) but one is by corsair and the other by OCZ. Safe to mix and match or just stick with one? Not really a big deal since its 3 gb v 4 gb :P
