CPU Liquid cooling
Post Date: 2011-05-15
coolmasta View Drop Down
  Quote coolmasta Quote  Post ReplyReply bullet Topic: CPU Liquid cooling
    Posted: 15 May 2011 at 7:17pm
Well Im thinking of learing about liquid cooling. Not really sure if I want to make the plunge or not. If I did does this look like a good kit to start with? http://www.dangerden.com/store/extreme-cooling-kit-1-2-inch-tubing-with-240mm-radiator.html#tabs
Edited by coolmasta - 15 May 2011 at 7:18pm
I7 2600k @ 4.5 Ghz, Noctua D14
8 Gigs Corsair 1600
HAF 922
Evga Gtx 580
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 15 May 2011 at 8:01pm
I'd say the better way is to pursue your own liquid cooling build over a pre-built system.
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 May 2011 at 3:45am
That kit does not consist of great parts.
Edited by DST4ME - 16 May 2011 at 3:45am
  Quote coolmasta Quote  Post ReplyReply bullet Posted: 19 May 2011 at 8:52pm
Danger Den not the place to look? Not really sure if I will be getting this my noctua is cool and quiet just cant help but tinker on my computer...
8 Gigs Corsair 1600
HAF 922
Evga Gtx 580
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 May 2011 at 12:09am
sidewinder is a good place, but its not about the place you go, its about the parts you use.
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 20 May 2011 at 4:44pm
Most likely you won't be buying parts from a single manufacturer. Don't be afraid to mix up brands, standard connectors exist for a reason.
FrozenCPU and SidewinderComputers are good places to hunt for parts.
Edited by ablahblah - 20 May 2011 at 4:44pm
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 May 2011 at 6:28pm
Well personally I'm not a big fan of frozencpu, they sent me some high cfm (200 cfm) fans, they get here, 4 of them are doa, I call them up, and they want me to contact delta, and say they haver nothing to do with it.
rholyrag View Drop Down
  Quote rholyrag Quote  Post ReplyReply bullet Posted: 21 May 2011 at 12:56am
I have bought from performancepcs several times, and it's been a good experience each time.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 May 2011 at 1:32am
I like performancepcs also
Zate View Drop Down
  Quote Zate Quote  Post ReplyReply bullet Posted: 24 May 2011 at 10:30am
Rasa 750 RX360 kit is a great place to start. Great block, great rad, the pump is ok for just a CPU loop, could probably use some better tubing eventually though.
Assassin On Order
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 May 2011 at 2:48am
I thought that didn't have support for the 1155 yet, or does the 1156 plate fit the 1155?
Edited by DST4ME - 25 May 2011 at 2:49am
This page was generated in 4.785156E-02 seconds.
