CPU temperature question
Post Date: 2010-08-30
Benson729 View Drop Down
  Quote Benson729 Quote  Post ReplyReply bullet Topic: CPU temperature question
    Posted: 30 Aug 2010 at 11:25am
I will be overclocking my cpu and I game in a small hot room. What is the best program/application for monitoring internal temperatures in my rig as I see that the temperature display enhancements are not recommended.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 30 Aug 2010 at 11:30am
  Quote Benson729 Quote  Post ReplyReply bullet Posted: 30 Aug 2010 at 11:48am
Awesome but will that work with i7 1366 it says latest update is for i7 1156?
Beezie View Drop Down
  Quote Beezie Quote  Post ReplyReply bullet Posted: 30 Aug 2010 at 11:51am
i believe it works for all processors
Dragoonseal View Drop Down
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 30 Aug 2010 at 12:09pm
The 1156 socket is newer than the 1366 socket.
Lilim
Intel Core i7 920 @4.2GHz
  Quote Benson729 Quote  Post ReplyReply bullet Posted: 30 Aug 2010 at 7:27pm
wait why are the new 980x chips running on 1366 and the 875 runs on 1156 which is more powerful 9 series or 8 series? Also why are DS p55 builds more affordable than x58? You just totally confused me.
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 30 Aug 2010 at 8:40pm
The 1366 socket (x58) platform is more powerful, and came out first. The 1156 socket (P55) came out later and is kind of a watered down version targeted at mainstream use.
The 9 series is more powerful than the 8 series.
Lilim
  Quote Benson729 Quote  Post ReplyReply bullet Posted: 30 Aug 2010 at 10:13pm
Ok so will sandy bridge, estimated to release early 2011, surpass 1366 or is it looking to be mainstream as well.
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 30 Aug 2010 at 11:20pm
LGA1155 is destined to be mainstream, near current i7 levels, by technical specs. Not sure about overclocking wise. LGA 2011 is destined to replace LGA 1136, and is for high end computing with a max of 16 threads via HT for that high end desktop line specifically.
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote Benson729 Quote  Post ReplyReply bullet Posted: 31 Aug 2010 at 12:03am
Any idea how long 1366 will be a capable gaming processor?
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 31 Aug 2010 at 8:46am
1366 isnt a processor its a platform
platform 775 and a q6600 is still a capable gaming setup, stop stressing about it, just buy what you can afford now and enjoy
Edited by !ender_ - 31 Aug 2010 at 8:47am
  Quote Benson729 Quote  Post ReplyReply bullet Posted: 08 Sep 2010 at 8:05pm
How far can an i7 950 be overclocked safely with only stage 2 noctua D14 cooling?
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 08 Sep 2010 at 8:43pm
dude. as the overclocker, that's YOUR job.Oops
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
JJJJ_Shabadoo View Drop Down
  Quote JJJJ_Shabadoo Quote  Post ReplyReply bullet Posted: 08 Sep 2010 at 9:11pm
Every individual processor will have different tolerances, but you shouldn't have a problem hitting at least 3.8 ghz and will probably be able to go even higher.
  Quote Benson729 Quote  Post ReplyReply bullet Posted: 09 Sep 2010 at 11:19am
It will be my first overclock and I can't afford to blow the processor.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 09 Sep 2010 at 11:55am
what i think he meant is that there is no "overclock this chip exactly like this"... its an art kinda, theres no right way, and every chip will reach different limits, different temperatures, etc
the hottest i would let one get is 80ish as a safe range, i believe the DSO website has 90c posted as the max safe cpu temp somewhere. ive been to 88 (yikes) but its just undue to put that much strain on your chip, id try and stay below 80 load.
contact dso or have them post directly before you make a choice on your limitation imo
