Custom Options for Avon 17 inch
Post Date: 2019-08-03
EricoDaBeast View Drop Down
  Quote EricoDaBeast Quote  Post ReplyReply bullet Topic: Custom Options for Avon 17 inch
    Posted: 03 Aug 2019 at 8:21pm
Hi guys,
I was considering buying an Avon 17 inch laptop but I was wondering if it was possible to have reduced noise from fans as well as heat because it really bothers me for some reason. I read from a review that it can get really loud and hot. I saw other companies offer thermal interface materials like Thermal Grizzly Conductonaut on CPU + GPU, and Fujipoly Extreme Thermal Pads on heat sensitive surfaces. Do you guys here at digital storm will be able to offer that or some other method to reduce heat and noise level?
  Quote hoserator Quote  Post ReplyReply bullet Posted: 04 Aug 2019 at 1:57am
Hi EricoDaBeast,
Welcome to DS.
Laptops by their design do get hot by just being on. There is just so much room for fans and heat dissipation and new tech does create more heat than in the past so.... The thermal additives only allow the heat to transfer to the cooling hardware. If the latter is inside a laptop it can only do so much.
This page was generated in 2.148438E-02 seconds.
