D3 running terrible 15-30 frames vanquish level 4
Post Date: 2015-04-15
Swap View Drop Down
  Quote Swap Quote  Post ReplyReply bullet Topic: D3 running terrible 15-30 frames vanquish level 4
    Posted: 15 Apr 2015 at 1:46pm
So I bought a Level 4 vanquish about a month ago, and started playing Diablo 3, and i can only run 15-30 frames in Diablo 3 while using the worst graphics system, Im pretty disappointing considering i spent 1400 on a computer that runs this game worse than my old laptop.... Anyone know why this is happening?
Username2380 View Drop Down
  Quote Username2380 Quote  Post ReplyReply bullet Posted: 15 Apr 2015 at 3:09pm
Has it been like this since you got the computer or just recently?
How do other games perform? You wouldn't be the first person to have problems with D3.
Update your drivers if you haven't already. A brand new Geforce driver came out earlier this week for GTAV.
Make sure you call the customer support line. 1-866-81-STORM
Edited by Username2380 - 15 Apr 2015 at 3:26pm
Pacesetter View Drop Down
  Quote Pacesetter Quote  Post ReplyReply bullet Posted: 15 Apr 2015 at 7:12pm
What is the speed and type of internet connection?
Did you try resetting the router?
Is that the GTX 970 video card?
Which motherboard do you have?
Single player? What area? Only in boss fights or all the time?
Have you run the network and connection troubleshooters?
Did you try updating the networking drivers?
Give us something to work with.
Vanquish II Ultimate.
Swap View Drop Down
  Quote Swap Quote  Post ReplyReply bullet Posted: 16 Apr 2015 at 1:11am
speed is 50 down 30 up ish - not worried about that
Reseting router dosent help
its a pny 970 gtx i believe.
I have the gigibyte motherboard
-- NVIDIA GTX 970 4GB
- Intel Core i5 4690K CPU
- 8GB 1600MHz Memory
- 250GB Samsung EVO SSD
- 1TB 7200RPM HDD
- Upgraded CPU Air Cooling
- Z97 Motherboard
- 750W Corsair CX Power Supply
- DVD-R/RW/CD-R/RW
- Microsoft Windows 8.1
I have the most recent graphic drivers as of 5 mins ago
single and multiplayer, gets worse with more player and more particles, physics ect...
What do you mean by network and connection troubleshooters? the lag is like farme based not lag
I can run counterstrike fine, same with skyrim, but in diablo im just dropping frames like crazy...
I did redownload diablo 3 with no sucess
Thanks for your replies guys, Ide like to get this all figured out. even just standing in town doing nothing with nothing moving around me it dosent pass 34 frames.
Edited by Swap - 16 Apr 2015 at 1:28am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 16 Apr 2015 at 3:40am
Hi Swap..... To eliminate heat as a problem on your gtx 970 that might throttle it, download HWMONITOR, free, and run it while gaming.   Check the cpu core temps and the gtx 970 gpu temps. Should be in the low 80s or less in Centigrade.   Ignore the Fahrenheit.
If you're not using audio through the gtx 970 HDMI to a monitor with speakers, meaning you're using seperate speakers or headphone, go into Device Manager, click on the audio section. Realtek and Nvidia audio will list. Right click and Disable all the Nvidia audio drivers. Those are only for audio passthrough for the gtx970.
Adjust, turn down, audio settings in game .
If you're using a monitor adapter like hdmi to dvi, vga to dvi, etc. , try a different one or use a different port on the gtx 970.
Hope this helps.
  Quote Pacesetter Quote  Post ReplyReply bullet Posted: 16 Apr 2015 at 12:48pm
Upload speed DOES count - should be 5+Mbs with your connection. Under 3 and you have MAJOR problems.
Any bad/slow step in the chain of servers can cause low FPS due to dropped packets - connection counts a whole lot.
In the game options under video - check the "max foreground FPS" box and set it to 150. Also check the "low FX" box and see if that helps. If it does, uncheck one at a time and try it to see which one helped the most.
Run a tracert from an elevated command prompt. (run as administrator.
This link will explain how) Replace the xxx.xxx.xxx.xxx with 12.129.202.154. This will show you what is happening along the way to the server.
https://us.battle.net/support/en/article/performing-a-traceroute#addresses
You can save the results to desktop and post it here if you like.
See my other post for a hotfix to latest driver and install that. http://www.digitalstormonline.com/forums/nvidia-350-driver-hotfix-tidf24606/
re-post with results.
NOTE: at the bottom of the page on running a tracert is a link to how to run a pathping. It will show if there is a problem with lost packets and where the losses occur. Use the same IP address as above.
"Im pretty disappointing considering i spent 1400 on a computer"
People with $7,000 computers are having the same problems.
Edited by Pacesetter - 16 Apr 2015 at 2:31pm
Swap View Drop Down
  Quote Swap Quote  Post ReplyReply bullet Posted: 16 Apr 2015 at 6:31pm
So Im not running my hdmi cable from my moniter to my graphics card, cause its a minihdmi on the card, so i am plugged into the one on the mother board, could this be the issue? should i get a mini cable? or a DVI cable, Have I been using my videocard at all by using this cable?
Im going to feel really stupid if thats the case, i set it up and just turned it on and didnt think about that until now...
Edited by Swap - 16 Apr 2015 at 6:33pm
  Quote Alex Quote  Post ReplyReply bullet Posted: 16 Apr 2015 at 6:39pm
Yes, that's the issue. You're using the Intel graphics on the CPU. You're not even using the dedicated graphics card. You'll get a big boost in performance.
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 16 Apr 2015 at 7:09pm
Gotta appreciate an easy fix at the very least! Strong
Swap View Drop Down
  Quote Swap Quote  Post ReplyReply bullet Posted: 16 Apr 2015 at 7:13pm
Im an idiot.... sorry for wasting your time guys... lol
I really do appreciate all your help and it did help lead me to my conclusion! I've never owned a computer with a separate video card before.
Edited by Swap - 16 Apr 2015 at 7:24pm
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 16 Apr 2015 at 7:29pm
Glad you got it worked out! Awesome
TankerT View Drop Down
  Quote TankerT Quote  Post ReplyReply bullet Posted: 17 Apr 2015 at 12:15am
Awesome! I just bought the same rig 3 weeks ago and was curious why your fps was so bad. Didn't DS include an adapter for your HDMI cable? They gave me one for mine. Kick ass machine DS!
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 17 Apr 2015 at 2:49am
Glad you got the issue ironed out. It is an easy mistake that many new to gaming rigs make. Enjoy.
Swap View Drop Down
  Quote Swap Quote  Post ReplyReply bullet Posted: 17 Apr 2015 at 12:52pm
Ah, they did now im looking at the box, good thing I just went out and bought a dvi cable... lol fml.
  Quote Username2380 Quote  Post ReplyReply bullet Posted: 17 Apr 2015 at 4:14pm
Just for laughs. What's your fps now?
Swap View Drop Down
  Quote Swap Quote  Post ReplyReply bullet Posted: 17 Apr 2015 at 6:28pm
60 vsync is enabled.
Edited by Swap - 17 Apr 2015 at 6:30pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 18 Apr 2015 at 2:36am
Nice.
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 18 Apr 2015 at 7:37am
 Strong
  Quote Alex Quote  Post ReplyReply bullet Posted: 18 Apr 2015 at 11:54am
  Quote Username2380 Quote  Post ReplyReply bullet Posted: 18 Apr 2015 at 5:09pm
So glad you can finally enjoy your computer to its fullest.
gbutts55 View Drop Down
  Quote gbutts55 Quote  Post ReplyReply bullet Posted: 21 Apr 2015 at 4:18pm
lol what a jabronie
curious to what you were playing the first month when you thought everything was fine.
Edited by gbutts55 - 21 Apr 2015 at 4:19pm
Swap View Drop Down
  Quote Swap Quote  Post ReplyReply bullet Posted: 21 Apr 2015 at 8:57pm
Originally posted by gbutts55
lol what a jabronie
almost exclusively CSGO, I had literally no issues with that game running from the motherboard lol...
Meller View Drop Down
  Quote Meller Quote  Post ReplyReply bullet Posted: 27 Apr 2015 at 2:05pm
Let's play!
http://us.battle.net/d3/en/profile/Miekster-1350/hero/60720243
Custom PC
Ryzen 9 5950X
Gigabyte X570 Aorus Xtreme
128GB DDR4 3600mhz
Samsung 980 Pro 512GB m.2
Samsung 960 PRO 2TB m.2 x2
Counsel View Drop Down
  Quote Counsel Quote  Post ReplyReply bullet Posted: 30 Apr 2015 at 5:41pm
I made the same mistake when I got my Slade last year, so don't feel too bad. Fortunately, the forum community helped me figure it out too. (Thanks guys!)
Proud Slade Owner
This page was generated in 6.835938E-02 seconds.
