DDL Sound Card that Supports 64-Bit?
Post Date: 2008-09-30
WeCanCallMeB View Drop Down
  Quote WeCanCallMeB Quote  Post ReplyReply bullet Topic: DDL Sound Card that Supports 64-Bit?
    Posted: 30 Sep 2008 at 10:11am
Hey guys and gals,
Quick question. I am guessing Widdlecat can probably give me the most insight.
What sound card would you recommend that is both Vista 64 compatible and supports Dolby Digital Live.  I'd like a cheaper one, but if that's not an option, then so be it.
I made the stupid mistake of buying a Turtle Beach Montego DDL on Ebay, which doesn't support 64-bit and judging by the non-existent support at Turtle Beach, probably never will.  Guess I'll be selling it and trying to get a new card... Wink
Thanks for any assistance.
Brandon
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 30 Sep 2008 at 4:09pm
I'm no expert but I know that the Razer Barracuda has it.
b20vtechb View Drop Down
  Quote b20vtechb Quote  Post ReplyReply bullet Posted: 06 Dec 2008 at 10:18am
http://www.auzensupport.com/data/PCI-8770-080421-8_17.zip
just use the auzentech driver
it installs and works perfect on the montego DDL on 64bit systems i've been useing this driver for months, a similar driver may exist on the cmi website as well
Edited by b20vtechb - 06 Dec 2008 at 10:19am
gamerk2 View Drop Down
  Quote gamerk2 Quote  Post ReplyReply bullet Posted: 08 Dec 2008 at 4:18pm
I know the Asus Xonar series supports more options for dolby sound, but I can't say anything about any particular feature...
Rad!caL View Drop Down
  Quote Rad!caL Quote  Post ReplyReply bullet Posted: 08 Dec 2008 at 10:09pm
Yeah the Xonar series (specifically the D2X) are excellent sound cards.
widdlecat View Drop Down
  Quote widdlecat Quote  Post ReplyReply bullet Posted: 10 Dec 2008 at 5:01am
The Razer Barracuda supports most dolby schemes, but not all. The ASUS Xonar is the best choice if you're looking for flexibility in home theater use. They cover all dolby set ups I know of. Auzentech is more like Razer in the home theater support, but has the added advantage of a well-executed X-Fi support.
