Default Chasis Fans
Post Date: 2021-11-09
Samuraiii View Drop Down
  Quote Samuraiii Quote  Post ReplyReply bullet Topic: Default Chasis Fans
    Posted: 09 Nov 2021 at 9:01pm
Hey what’s going on. I made and purchased a build but the weird thing is I chose the lynx case even though I wasn’t doing a lynx build but a much more powerful build because I liked the case and it saved a bit of money. Although I didn’t choose the Rgb fans that they offer I really wish I could have switched to them because now I’m not so sure about the factory fans that come with the lynx case. I was wondering if they were still just as efficient as the Rgb ones and what rpm they run at. Thanks gents ✌️🙏
Good Game Gentlemen… *Samuraiii* ^_^
JamesAstro View Drop Down
  Quote JamesAstro Quote  Post ReplyReply bullet Posted: 09 Nov 2021 at 10:07pm
I don't know much about the default case fans in the Lynx. However, if you want full control over the fan speed, you should also think about getting the Corsair Commander Pro. It makes it easy to set fan speed curves based on the temperature.
I actually had Noctua fans put into my Velox machine, and they are controlled by the Corsair Commander Pro. Noctua fans are quiet and efficient. They don't look as cool as the Corsair RGB fans though.
  Quote Samuraiii Quote  Post ReplyReply bullet Posted: 09 Nov 2021 at 10:19pm
No that’s ok man, I have noctua aswell but I really only am interested in info for the factory chasis fans. I don’t plan on using them with my build i just really need some info for research and review purposes lol.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 10 Nov 2021 at 4:38am
AFIK, the RGB fans are automatic if you order the LYNX. There seems to be a glitch in the Configurator where if you start with a Lynx chassis, you get them because they ARE stock. If you choose another chassis and SWITCH to a Lynx, the RGB fans don't show up as standard. Check with DS to be sure, but I doubt they remove RGB fans that come with the case just because you opted for it from another build. I hope you're pleasantly surprised!
  Quote Samuraiii Quote  Post ReplyReply bullet Posted: 10 Nov 2021 at 5:55am
That would be so dope to get the Rgb fans instead of garbage stock fans I think I would be surprised very much.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 11 Nov 2021 at 5:27am
IDK how far along you are, but it doesn't hurt to ask. I could be all wrong, but it doesn't make sense they would pull RGB fans from a case that comes with them stock. My bet is you have 'em, but if I'm wrong you SHOULD have 'em by all rights. Make sure.
