Difference between ASUS and original AMD 6950 card
Post Date: 2012-01-21
chinoy View Drop Down
  Quote chinoy Quote  Post ReplyReply bullet Topic: Difference between ASUS and original AMD 6950 card
    Posted: 21 Jan 2012 at 12:44pm
I'm trying to figure out the difference between the regular radeon 6950 vs the one by ASUS.
the card itself looks very different.
Here is the ASUS mmodel:
http://www.asus.com/Graphics_Cards/AMD_Series/EAH6950_DCII2DI4S2GD5/#specifications
(this is what DS gave me)
Here is the what the AMD site shows:
http://www.amd.com/US/PRODUCTS/DESKTOP/GRAPHICS/AMD-RADEON-HD-6000/HD-6950/Pages/amd-radeon-hd-6950-overview.aspx#1
The AMD one is the one I ordered when I went through the system configuration... The picture matched what the AMD site shows.
Now the question is was I shortchanged?
Showing me one but giving me another one does not seem right....
help me understand this
Ray
  Quote Alex Quote  Post ReplyReply bullet Posted: 21 Jan 2012 at 12:47pm
The ASUS unit is a better card due to a better high-performance cooling system.
  Quote chinoy Quote  Post ReplyReply bullet Posted: 21 Jan 2012 at 12:47pm
Quick follow up:
Mine is a 2GB card. From the picture, it seems the ATI/AMD branded one takes up 2 slots in the back, where as my ASUS takes up 3 slots..
I have 2 of these and so 6 clots are taken up... which leaves VERY small wiggle room inside my case
jmaster299 View Drop Down
  Quote jmaster299 Quote  Post ReplyReply bullet Posted: 21 Jan 2012 at 1:21pm
Yeah just like Alex said it's the special cooling system that ASUS put on the card. Now if you read the description for the ASUS card you will see that the beefed up cooling system is designed for people who want to over clock their GPUs. In addition to the cooling system the ASUS card has a special voltage tuner for the over clocking.
Now normally over clocking your GPUs is not recommended as the frame rate boost is typically only in the single digits but it causes the cards to usually have a very shot life span. Hence why ASUS improved the cooling on the card as most GPU over clocking will give you undesirable temps.
So unless you are going to over clock your cards, which I would not recommend, those cards are a waste of space and money. The advertised "2.5x longer life span" that ASUS is claiming on their site is subjective at best and more then likely completely bogus.
A non-overclocked GPU will last you more then 2 years and 2 years is how often you should be upgrading your GPUs to keep your rig current. Overclocked GPUs can often die in a year or less and that's why they need the "longer life span".
Edited by jmaster299 - 21 Jan 2012 at 1:26pm
