Difference between DDR3 OCZ and DD3 Corsair?
Post Date: 2008-08-04
david5182 View Drop Down
  Quote david5182 Quote  Post ReplyReply bullet Topic: Difference between DDR3 OCZ and DD3 Corsair?
    Posted: 04 Aug 2008 at 1:09pm
Can someone please tell me what is the difference between DDR3 OCZ at 1600MHz Platinum Edition and DDR3 Corsair at 1600MHz DHX? Is it the timings?
Is it worth paying extra $78 to get DDR3 Corsair at 1600MHz DHX?
Thanks.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 04 Aug 2008 at 4:35pm
not sure about the brand but will tell you to make sure you match your ram speed with your processor's fsb
SunfighterLC View Drop Down
  Quote SunfighterLC Quote  Post ReplyReply bullet Posted: 04 Aug 2008 at 5:33pm
Im not sure of the type of DHX 1600 they use corsair sells two types a CAS9 and a CAS7 version. You might want to ask them which they sell.
Im assuming its the CAS9 though, and since DS only seems to sell 1GB versions unless you specify im gonna link you the 2x1 versions...
Corsair DHX CAS9
Corsair DHX CAS7
OCZ Plat CAS7
IMHO OCZ is a little cheaper made overall, which reflects in price and they seem to have a slightly higher failure rate, but their performance vs price is unbeatable. Corsair has sort of an inflated price thanks to their brand name being well reguarded but their ram is usually very solid.
E8500@ 4.03Ghz
XFX 790i Ultra
1000W Corsair HX
2 280 GTX EVGA FTW
4GB OCZ Reaper 1800Mhz
250-80-300GB VR HD
Logitech Z-2300 2.1 Speakers
Asus Xonar 7.1
  Quote david5182 Quote  Post ReplyReply bullet Posted: 04 Aug 2008 at 5:59pm
Thanks guys.
But can someone from DSO please respond? Alex?
