Display Port cable to use?
Post Date: 2020-09-09
Seraphic View Drop Down
  Quote Seraphic Quote  Post ReplyReply bullet Topic: Display Port cable to use?
    Posted: 09 Sep 2020 at 2:44pm
Hey gang,
Looking at ordering this monitor to go with the newer DS rig I received:
ASUS ROG Strix XG27UQ 27"
Using a 2080 super at the moment. Looking at a display port cable and was guided to this one:
https://www.amazon.com/CABLEDECONN-Copper-DisplayPort-32-4Gbps-Flexible/dp/B00V7NOST8/ref=sr_1_1_sspa?dchild=1&keywords=display%2Bcable%2B8k&qid=1599686430&s=pc&sr=1-1-spons&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyRDVPOFNSWFNUT1dCJmVuY3J5cHRlZElkPUEwNTY2NTYwM0JYTzhKVlFRTEY5NyZlbmNyeXB0ZWRBZElkPUEwMzIyMDM3M05PUTgxOUxFWFg5WSZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU&th=1#Ask
The Fiber 10m. Is that overkill? Is there something better?
  Quote Cretae Quote  Post ReplyReply bullet Posted: 10 Sep 2020 at 3:51am
Generally speaking, paying a bizillion $$ for a fancy cable does nothing but make your wallet lighter. Why would you need 33 feet of cable from your PC to your monitor? If you have a run like that, the signal can degrade, but not in a typical 2-6 feet.
Here's a handy quote from an article I read:
"While retailers may try to sell you a more expensive cable touting it will provide a better picture quality, we are here to debunk that myth. Contrary to what you may think, the more expensive cable will not give you a better picture quality. DisplayPort uses packetized data, similar to USB and Ethernet, to send digital display and audio data, therefore you either get all of the data or you don’t. Unlike other older video interfaces, you don’t get a “better” picture or other incremental improvements with a more expensive cable."
My $12 display port cable works just fine, but my monitor doesn't need much.
Edited by Cretae - 10 Sep 2020 at 5:06am
  Quote Seraphic Quote  Post ReplyReply bullet Posted: 10 Sep 2020 at 4:57am
My $12 display port cable works just fine.
What display port cable would you suggest? I didnt realize how long it was. I was looking more at the material it was made from ;p
  Quote hoserator Quote  Post ReplyReply bullet Posted: 10 Sep 2020 at 5:10am
The monitor comes with cables but if you need longer make sure they are VESA cert and min. DP 1.4 (recomended for that particular monitor, DP 1.2 will limit the monitor to 4K@60Hz.)
Edited by hoserator - 10 Sep 2020 at 5:14am
  Quote Cretae Quote  Post ReplyReply bullet Posted: 10 Sep 2020 at 5:10am
Actually, I was just looking at the same thing at 2 meters on Newegg for $19.
https://www.newegg.com/p/183-008N-00049
