do i need more power?
Post Date: 2008-05-09
brian View Drop Down
  Quote brian Quote  Post ReplyReply bullet Topic: do i need more power?
    Posted: 09 May 2008 at 12:02am
im looking at a rig with these specs.
550w psu
x48 mb
1066mhz of ddr2
8400 oc'd
8800gts
now the question i have is...is this enough power or do i need to go with 620w?
Edited by brian - 09 May 2008 at 12:06am
Bill the Cat View Drop Down
Forum Bitch!
  Quote Bill the Cat Quote  Post ReplyReply bullet Posted: 09 May 2008 at 9:24am
For an almost identical system, I was told by a couple of people at DSO that 550 W was enough as long as you have no plans to ever go Crossfile or add a bunch of disk drives. You didn't mention your HD config. Drives can suck up a lot of power.....
  Quote brian Quote  Post ReplyReply bullet Posted: 09 May 2008 at 10:17am
oh a 250gig and maybe a external down the road. im not sure if ill go crossfire since i will be using a 22". but isnt the psu easy to replace if need be?
Drakul View Drop Down
  Quote Drakul Quote  Post ReplyReply bullet Posted: 09 May 2008 at 10:33am
They are fairly easy to replace, but hard to wire as neatly as DS does.
traylorc View Drop Down
  Quote traylorc Quote  Post ReplyReply bullet Posted: 09 May 2008 at 11:39am
Personally, whenever I purchase any electronics I always try to buy a little more than I currently need.  But that's just me.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 09 May 2008 at 7:10pm
same, i would get 620
This page was generated in 8.911133E-02 seconds.
