do i need stage 3 cooling?
Post Date: 2008-05-04
brian View Drop Down
  Quote brian Quote  Post ReplyReply bullet Topic: do i need stage 3 cooling?
    Posted: 04 May 2008 at 8:19pm
im getting closer to finally buying my puter. but i do have more questions.
im getting the cosmo case and with all of the fans it comes with (i think 5) should i get stage 3 cooling? i dont think they can add more to the case so really its just going to be fan upgrades. i may overclock my cpu.
skyR View Drop Down
Digital Storm Apprentice
  Quote skyR Quote  Post ReplyReply bullet Posted: 04 May 2008 at 8:26pm
Cosmos S comes with 4 fans with the possibility of adding 3 more fans for a total of 7.
SunfighterLC View Drop Down
  Quote SunfighterLC Quote  Post ReplyReply bullet Posted: 04 May 2008 at 8:56pm
Is this the Cosmos S or the Cosmos case you are talking about Brian?
E8500@ 4.03Ghz
XFX 790i Ultra
1000W Corsair HX
2 280 GTX EVGA FTW
4GB OCZ Reaper 1800Mhz
250-80-300GB VR HD
Logitech Z-2300 2.1 Speakers
Asus Xonar 7.1
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 04 May 2008 at 9:28pm
yes overclocking, yes stage 3
no overclocking, stage 2
  Quote SunfighterLC Quote  Post ReplyReply bullet Posted: 04 May 2008 at 9:59pm
Those 3 extra fan places, those are all on the top of the case right?
Im actually suprised the Cosmos S doesnt hold more fans then that.
I thought also that the Cosmos S comes only with 3 fans, the 200mm+ one on the side, then 2 in the upper left side of the case. Just wondering where the 4th one would be.
E8500@ 4.03Ghz
XFX 790i Ultra
1000W Corsair HX
2 280 GTX EVGA FTW
250-80-300GB VR HD
Asus Xonar 7.1
skyR View Drop Down
  Quote skyR Quote  Post ReplyReply bullet Posted: 04 May 2008 at 10:25pm
Cosmos S comes with two exhaust fans (one top & one rear) and two intake fans (one side and one front).
You can add two more 120mm fans at the top of the case and one 120mm fan at the bottom of the case.
  Quote SunfighterLC Quote  Post ReplyReply bullet Posted: 04 May 2008 at 10:32pm
Sounds perfect =P okay, 100% sure now minus DS trying to convince me its not. yay! 5 days to go before i order! *yes i know im ordering on a friday..lol...but that payday for me!
E8500@ 4.03Ghz
XFX 790i Ultra
1000W Corsair HX
2 280 GTX EVGA FTW
250-80-300GB VR HD
Asus Xonar 7.1
  Quote brian Quote  Post ReplyReply bullet Posted: 04 May 2008 at 11:10pm
im talking about the regular cosmo. but im wandering that with all those fans that come with the case...is it a good choice to go stage 3? and will ds add more fans if i pay for stage 3 or just upgrade the 4 or 5 it comes with?
Tyler Lowe View Drop Down
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 05 May 2008 at 12:14am
They fill every fan mount in the case with high quality fans.
I'd just do it. It's the best cost to benefit ratio you are likely to find on the configuration page.
  Quote brian Quote  Post ReplyReply bullet Posted: 05 May 2008 at 12:45am
yeah i should get the good fans. over here in okinawa it gets hella humide and hot.
