Does Bolt X case allow a capture case inside
Post Date: 2019-10-17
Dragro2k View Drop Down
  Quote Dragro2k Quote  Post ReplyReply bullet Topic: Does Bolt X case allow a capture case inside
    Posted: 17 Oct 2019 at 9:12pm
I was wondering if I can add an elgato 4k capture card inside the desktop or if it'll be too small of a space.
If not what'll be recommended for ultra settings in all games but can also stream with good FPS along with having the capture card availability slot inside.
HockeyBuck View Drop Down
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 17 Oct 2019 at 9:34pm
Nope....because Bolt X is a very small form factor case that uses a mini ITX motherboard with only one PCIE slot that is needed for the GPU that is placed on a extension riser.
You would need to select one of the DS full sized Lynx, Lumos, Velox or Aventum X configurations using a full sized ATX motherboard with at least two or more PCIE slots so you can use a dedicated GPU in one slot and your 4K capture card in a second PCIE slot.
The very best NVidia RTX 2080 Ti 11 GB VRAM GPU would be absolute king of the 4K gaming performance market.
