downsides of running really hot?
Post Date: 2008-06-05
MarkNY View Drop Down
  Quote MarkNY Quote  Post ReplyReply bullet Topic: downsides of running really hot?
    Posted: 05 Jun 2008 at 10:17am
So- to gain some consensus, is there any downside to running my processor really hot under load?
right now vcore is set at 1.45 and while playing crysis at 1980x1200 with everything at very high the temp goes into the low 90s C.  However, there doesn't seem to be any stability issues.  I Played for 2 hours last night and didn't run into any problems.
So is there any downside to running this hot other than damaging the life of the processor?  I plan to buy a new computer in a year and half anyway, so should this matter?
Thanks!
EdH63 View Drop Down
  Quote EdH63 Quote  Post ReplyReply bullet Posted: 05 Jun 2008 at 10:25am
Considering the way your speced out, your rig is designed to run at temps like that and be fine.  If you can make it it to your term without meltdown, then more power to ya.  There's always that variable factor that floats which could break you sooner than you'd like, but that factor floats with all of us, too.  You just never really know how it's going to hold up under that kind of stress.
It's kinda like a drag race in a super hopped-up alcohol burning rail car.  You hit the gas and scream down the line at almost 300 miles per hour and pray to your sweaty balls that you don't disintegrate before you reach the finish line.
skyR View Drop Down
Digital Storm Apprentice
  Quote skyR Quote  Post ReplyReply bullet Posted: 05 Jun 2008 at 11:50am
Running it hot decreases the component's lifespan.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 05 Jun 2008 at 7:10pm
seems wierd to me that youd hit those temps with liquid cooling
Kliebor2 View Drop Down
  Quote Kliebor2 Quote  Post ReplyReply bullet Posted: 05 Jun 2008 at 7:18pm
Seems odd also to me, unless the ambient in the room is really up there and the liquid can't cool down effectively due to that.
Dual PNY OC2 GTX 560Ti
8 Gigabytes DDR2/800
Bill the Cat View Drop Down
Forum Bitch!
  Quote Bill the Cat Quote  Post ReplyReply bullet Posted: 05 Jun 2008 at 11:59pm
Of course, the processor's probably going to halt if it hits 100C.
When you pray to your balls, EdH, do they talk back?
Edited by Bill the Cat - 06 Jun 2008 at 12:03am
Tyler Lowe View Drop Down
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 06 Jun 2008 at 12:01am
He's cooling both a hot processor and two very hot running GPU's with a single loop liquid cooling solution. Those temperatures are not out of line.
  Quote EdH63 Quote  Post ReplyReply bullet Posted: 06 Jun 2008 at 1:35am
I actually had a picture of you in my head doing that when I posted.
Edited by EdH63 - 06 Jun 2008 at 1:35am
bfrank2me View Drop Down
  Quote bfrank2me Quote  Post ReplyReply bullet Posted: 06 Jun 2008 at 3:24pm
Excuse me while I poke out my mind's eye.
...the first hundred years are the hardest
  Quote Kliebor2 Quote  Post ReplyReply bullet Posted: 06 Jun 2008 at 3:27pm
Looks like Ed is joining Bill in the gross mental imagery club :)
  Quote EdH63 Quote  Post ReplyReply bullet Posted: 06 Jun 2008 at 3:32pm
Hey, I wrote the book.  Bill's just a saucy new chapter.
  Quote Kliebor2 Quote  Post ReplyReply bullet Posted: 06 Jun 2008 at 3:34pm
Ah... so you then would be the Guru of Gross, the Emperor of Ewwww....
hmmm... I wonder should we all genuflect?
  Quote EdH63 Quote  Post ReplyReply bullet Posted: 06 Jun 2008 at 5:55pm
Yes, yes and... yes.
Forum Bitch!
  Quote Bill the Cat Quote  Post ReplyReply bullet Posted: 06 Jun 2008 at 9:53pm
Nice lob, Kliebor2. Your question suggests a number of different possible answers; none of which, unfortunately, can be proposed here....
Edited by Bill the Cat - 06 Jun 2008 at 9:56pm
  Quote EdH63 Quote  Post ReplyReply bullet Posted: 06 Jun 2008 at 11:16pm
I would prefer a double genuflection for better stability.
