Drain Valve
Post Date: 2009-10-15
Psimon View Drop Down
  Quote Psimon Quote  Post ReplyReply bullet Topic: Drain Valve
    Posted: 15 Oct 2009 at 7:44am
Could some LC veteran help me out in ordering the new parts for building a drain valve?
I don't want order until I'm certain everything is compatable (fits together).
Relevant specs:
Pump: Swiftec MCP355
Tubing: Tygon R3603 3/8" ID 5/8" OD
Ball Valve with 2 3/8 ID 5/8 OD Compression Fittings: http://www.koolance.com/water-cooling/product_info.php?product_id=918
2-3' Tubing, Clear UV-Reactive PVC, 1ft/30.5cm [ID: 10mm (3/8"); OD: 13mm (1/2")]
I don't think that 4-way is compatable with the fittings/nozzles (compression, barbed). It states that it has "four G 1/4 BSP" threaded nozzle holes. With my LC system, I'd probably be looking for a 4-way with 5/8" threaded holes? Or I have to use some kind of adapters?
I'll keep looking for another 4-way, although I wish I could just order everything from the same site. It SAYS that 4-way can be used with any nozzle size, but not sure that's true.
Essentially what I want is similar (or exactly) to Justin's example below. The four way will (probably?) fit on the coolant pump's outlet (to CPU) hose. Straight through route will go to the CPU waterblock, "optional" route to the Ball Valve -> Drain Hose
Edited by Psimon - 15 Oct 2009 at 7:47am
CM HAF 932*EVGA X58 3X SLI* i7920 4.0Ghz OC*6GB Mushkin RAM*EVGA Titan Sprclked*Samsung 850 Pro 1TB*Logitech Z5500*Razer Death Adder*Corsair 1000HX PSU*LG 34UM95 Monitor*Windows7Ult64
  Quote Psimon Quote  Post ReplyReply bullet Posted: 02 Nov 2009 at 6:42am
It would seem that the easiest solution would be to simply purchase two pairs of QDC's, one inline with the motor output (to CPU) and the second attached to a drain hose.
Unfortunately the QDC's featured in the DS video were not used in the construction of my Frostbite system.
Edited by Psimon - 02 Nov 2009 at 6:43am
